Old 02-01-2010, 03:37 AM   #1
mistermike's Avatar
1968 17' Caravel
Marblehead , Hasslechusetts
Precision Rivet Removal Tools
I recently did some research into the subject of removing rivets that are used to fasten the exterior and interior panels together. Here are my findings.
The exterior aluminum panels are fastened together using 5/32" buck rivets. They are installed by placing a piece of metal, called a "bucking bar", behind the rivet and compressing them with a special tool. So-called "pop rivets" (also referred to as "blind rivets" use a metal shank that pulls the back of the rivet causing it to mushroom when used with the installation tool, thus keeping everything in place.
Neither type of rivets are reusable. In order to remove them they have to be drilled. This is not too complicated a procedure in itself but removing rivets especially from the outer shell must be done with great care and attention; otherwise you may risk damaging the Alclad aluminum plate should the drill slip and move while you are drilling. You may also enlarge the hole which could lead to waterleaks later.
The traditional method is to use a spring-loaded center punch, such as the Starrett #18-AA or Stanley model #1113 to create a dimple in the head of the rivet. Then carefully drill into the dimple you created using a #21 drill bit until the head comes off.
I found a couple of very useful rivet removal tools used in the aviation industry that are available to make this procedure much simpler and less stressful. Several companies sell them and they're all pretty much the same except for one manufactured and marketed by a small company up in Michigan named Aircraft Tool Supply (ATS). This tool, P/N 1341S offers an important feature that the others lack - More about this model later.
The rivet removal tools come with four cobalt-tipped drills and matched nosepieces in the following sizes: #40 (3/32"), #30 (1/8") (as used on the interior panels), #21 (5/32") (as used on the exterior panels) and #12 (3/16"). You can adjust the depth of the drill stop which means you will only drill as deep as necessary to remove the rivet head which is a very nice feature. Drill sizes are as used in the aircraft industry and the fractional size equivalents are approximate.
All the rivet removal tools are precision items but the standard model is really only suitable for buck rivets that tend to stay in place when drilled whereas the ATS 1341S works well with all kinds of rivets. I found it easy to use and was able to remove several rivets cleanly and quickly, using it with my DeWalt 3/8" cordless drill.
Sometimes the the torque of the drill may cause a rivet to spin. This can make the task more difficult and increase the potential for damage to the aluminum plate. The difference between the models is that the ATS P/N 1341S features serrated nosepieces that grip the rivet head and keep it from spinning as it is being drilled. This is more likely to occur when working with pop rivets but any rivet being drilled has the potential to spin. In my opinion it's well worth the additional cost to have the serrated nosepieces in case this happens.
Unfortunately, none of these rivet removal tools come with any documentation such as instructions for use. Perhaps it is assumed that anyone requiring this tool for use on airframes is familiar with its use. However it is pretty simple to figure out and I was able to make the following notes on how it is used.
The tool must be set up with the matching drill and guide as selected according to the size of the rivet shank you are removing. At the top there is a shank that goes into your drill's chuck. Unscrew this piece and remove it from the sleeve along with the spring. Install the correct size drill. Set aside. Unscrew the nosepiece and separate the locking
ring from the nosepiece. Now screw the top part containing the drill into the sleeve. You will notice that the shank and drill are spring-loaded. Select the nosepiece that matches the drill you previously installed. Screw on the knurled locking ring as far as it will go. Install the nosepiece that matches the drill size you are using. Slide the nosepiece over
the drill and screw it into the sleeve. It is at this point that you will adjust the depth stop feature keeping in mind the preset distance for drill travel is 1/4". Finally use the knurled locking ring to lock the nosepiece to the sleeve.
Once the tool is properly set up it is a simple matter to remove rivets quickly and safely. Just insert the shank into your drill's chuck and tighten, remembering to make sure there's about 1/4" travel room when the spring in the tool is compressed. Place the nosepiece over the rivet.
Holding the tool's knurled sleeve with one hand operate the drill with the other and press down on the rivet drill until the tool reaches the preset stop. The rivet head will fall off. It's that simple.
My conclusion are that both models will work perfectly for drilling the 5/16" exterior rivets. However if you feel you will be dealing with the 1/8" internal pop-rivets as well you should consider the additional $20.00 for the 1341S model a worthwhile investment.
For more information go to www.aircraft-tool.com and search on 1341S.
"Mister Mike", Chief Engineer, Amateur Radio Station W1RC
Founder and Benevolent Dictator, New England Amateur Radio Festival, (aka NEAR-Fest),
At the Beautiful Deerfield NH Fairgrounds (Next one May 4th and 5th 2018)
"Best #@! Hamfest on the Planet!"
www.near-fest.com
mistermike is offline   Reply With Quote
Old 02-01-2010, 06:41 AM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Rivet Removal Tool
Dito: Mistermike great info- I struggled removing rivets on my 65 until I purchased the Rivet Removal tool from Aircraft Tool Supply. This tool really makes the job easy and precise. I got the info on this tool from this forum on another thread about 3 months ago. This one is well worth the money....tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 02-01-2010, 07:24 AM   #3
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Great information! Thank you!
2vets is offline   Reply With Quote
Old 02-01-2010, 07:47 AM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The exterior skins are riveted on with 1/8" brazier head rivets which are commonly replaced with 5/32" universal head rivets.
Old 02-27-2010, 12:04 PM   #5
1970 23' Safari
Ventura , California
Question: If I use olympic rivets or large flange rivets from vintage trailer supply do I need a rivet shaver? Would I need to shave EACH and Every rivet? This is for my underbelly...
jaminalee is offline   Reply With Quote
Old 02-27-2010, 12:11 PM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi jaminalee, You would only use large flange rivets on the belly pan and they do not need to be shaved.
Olympic rivets replace buck rivets and use a shaver. You can use a dremel to make them look pretty good in case you don't go with a rivet shaver.
This section will help you. Ribs, Skins & Rivets - Airstream Forums
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-27-2010, 12:14 PM   #7
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
no
i've used large flange from vts. they work well, no shaving needed as they act like a pop rivet. - i would use a shaver on the show rivets. expensive but well worth it.
alclad is offline   Reply With Quote
Old 03-04-2010, 06:46 AM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Ditto on the rivet removal tool! I bought one from ATS also, and made my rivet removal life complete! Last I looked they were on sale for 39.95.Be sure and get additional bits as they are threaded and not something you can buy at HD.They are carbon and last a long time ,but sometimes you just break one.
bwaysteve is offline   Reply With Quote
Old 03-04-2010, 07:33 AM   #9
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
I also bought a rivet removal tool from ATS. Worth every penny!
Birdwell57 is offline   Reply With Quote
Old 03-04-2010, 08:01 AM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The PO of my trailer used a large headed rivet to attach a home made shroud over the AC. I want to install something that looks better. The rivets have a head about the size of a 50 cent piece. Looks like a pop rivet on steriods. Is this the right rivet to use? Looks like it could leak. If it is. Where do I get some?
Old 03-04-2010, 01:55 PM   #11
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I hate to be the dissenting voice here, but I didn't think the rivet removal tool was worth a hoot. I found it just as easy to set the bit by turning it backwards by hand a 1/4 turn then drilling the rivet out. We've replaced several panels plus all our drip caps, windows, belly skins and never had a single slip off the rivet using this technique - well over 1000+ rivets.
Sold the tool...bought more rivets!
Shari
Old 03-04-2010, 02:12 PM   #12
Images: 59
Originally Posted by InsideOut View Post
I hate to be the dissenting voice here, but I didn't think the rivet removal tool was worth a hoot. I found it just as easy to set the bit by turning it backwards by hand a 1/4 turn then drilling the rivet out. . . .
Shari
Another dissenting voice. I had the same result except I turned the bit forward 1/4 turn. If you keep a sharp bit that's all you need.
Old 03-04-2010, 08:48 PM   #13
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
To each his own.I just found after awhile the spring enabled me to just punch in the bit and on to the next.Had a serendipitous rhythm to it.
Old 03-05-2010, 08:41 AM   #14
Aerowood's Avatar
Arvada , Colorado
Practice, Practice, Practice. I'm going to go out on a limb here and state that I have probably drilled out more rivets then anyone else on the forums, maybe, and I do not own a rivet removal tool. They work well but I have found they just slow me down. One of the reasons that they do work well is the type of drill bits they use. They are 135 degree split tip type bits. Using the same type split tip high quality bits, that are not threaded, in a 2500 - 3000 rpm drill will give equal results.
Olympic rivet tools smallfry Ribs, Skins & Rivets 9 10-16-2014 05:37 PM
Rivet installation tools ...?? aircooled4 Ribs, Skins & Rivets 2 10-19-2008 06:44 AM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Rivet Tools markdoane Ribs, Skins & Rivets 71 03-29-2005 06:30 PM
