Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 12-06-2004, 10:00 AM   #1
idahosafari's Avatar
Pre-coated Alcoa aluminum panels
I heard that recently Airstream began using pre-coated Alcoa aluminum panels rather than applying a clearcoat as they had previously done.
Can anyone tell me what year Airstream began using pre-coated Alcoa aluminum panels, and how well have they held up compared to the clearcoat?
Thanks!
- Charlie
2004.5 Dodge 4X4 Quad Cab w/Cummins Turbo Diesel
idahosafari is offline   Reply With Quote
Old 12-06-2004, 10:51 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Thanks!
- Charlie
I believe it was in 1999. I think it's too soon to tell. It was my understanding that some clearcoats started to fail between 5-10 years. The pre-coated stuff has barely been out in the field for 5 years.
Old 12-06-2004, 11:46 AM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Oasis RV in Tuscon Az has a shell sitting in their back yard that Airstream sent them several years ago to see how the clearcoat holds up in the hot desert sun - so far so good.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 12-06-2004, 03:42 PM   #4
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
If you want a little more info straight from Alcoa, see http://www.alcoa.com/car_truck/en/success_airstream.asp
rluhr is offline   Reply With Quote
Old 12-06-2004, 04:33 PM   #5
Tinsel Loaf's Avatar
Ours started to craz and bubble on a coupel panels after 12 months. Airstream replaced the street side panel under warranty.
Tinsel Loaf is offline   Reply With Quote
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
aluminum restoring rdm Cleaning, Stripping & Polishing 1 02-27-2002 11:37 AM
