Old 10-22-2011, 01:43 PM   #1
vintageair's Avatar
1955 16' Bubble
Europe , glous
Pre 1958 - Fabrication of end cap panels
Hello,
I'm looking for someone that can supply the tooling ( up to 6ft ) or sheet with the correct edge profile for 13 panel trailers.
Needs to be a 99.7% match for the original.
Does anyone recall any previous postings on this or has anyone had success in producing an exact replica panel.
Sam.
Name:	Screen shot 2011-10-22 at 20.32.42.png
Sam
WBCCI #1234 Nebraska - My trailer is the #1
www.vintageairstreams.co.uk
https://twitter.com/carryonglamping
www.99point7percentpure.blogspot.com
vintageair is offline   Reply With Quote
Old 10-22-2011, 02:02 PM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I don't have that style end cap but in your photo it just looks like a bead rolled edge, you can get or make a hand sized tool for that.
truckasaurus is offline   Reply With Quote
Old 10-22-2011, 02:06 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
send me a PM...how many do you want?
Old 10-22-2011, 03:03 PM   #4
vintageair's Avatar
1955 16' Bubble
Europe , glous
I'm thinking this has been covered many times already on the forums, but i just could not find the right thread.
It's slightly more than a rolled edge. The edge profile has been formed with tooling that leaves not only a rolled edge but also a line pressed into the side of the roll which is away from the edge of the material.
It appears a simple tooling, but would cost me a good bit to get made up to replicate the original.
I'm looking for an exact/99.7% match to the original.
Many thanks,
Sam.
Sam
Old 10-22-2011, 05:18 PM   #5
1960 33' Custom
I'll take a snap of the tools I have at the shop for this and see if it's the same thing.
Old 10-22-2011, 07:22 PM   #6
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I cut out my blanks and took them to a local sheet metal shop, I took along an old segment and said please match. Im happy with the way they turned out
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 10-23-2011, 08:05 AM   #7
vintageair's Avatar
1955 16' Bubble
Europe , glous
Brad,
I had a look at your work, very nice. That was pretty bad damage you fixed.
Would you have a close up of the bead your local sheet metal shop produced?
I wonder how Airstream did it back in the fifties, would they have rolled the bead in or pressed them?
These seems good, if they come with the right dies/mandrels -
Eastwood Bead Roller and Flanger Kit - YouTube
Sam
Old 10-23-2011, 04:38 PM   #8
BradS's Avatar
1957 26' Overlander
Images: 14
The bottom bead is the factory and the next one up is new
WBCCI 10289
TAC MN-69
AIR 11240
Old 10-24-2011, 01:31 AM   #9
vintageair's Avatar
1955 16' Bubble
Europe , glous
Brad,
That looks very close.
Just one little thing, looking at the bead, there appears to be an extra profile line on the edge side of bead, it that correct?
I wondered if anyone has managed to get a the exact bead replicated and if so, what roller/die set/mandrel setup would they recommend using for a small workshop. Something with the flanging capabilities would be a bonus.
Many thanks,
Sam.
Name:	Screen shot 2011-10-24 at 08.21.21.png
Sam
Old 10-24-2011, 03:09 AM   #10
Baltimore , Maryland
The bead you seek is not a uniform bead. It changes slightly year to year and dramatically from California to Ohio. To get a 99.7% perfect match will require matching the year and factory.
PS, 99.7% perfect is going to be nearly impossible to achieve. We are humans and we are fraught with error. Aluminum can only be 99.7% pure after extensive purifying. Bleach can only kill 99.8% of what it contacts. The birth control pill is only 99.6% effective allowing for 4 out of a thousand pregnancies.
It is very admirable to hold others to such standards however.
Old 10-24-2011, 12:19 PM   #11
vintageair's Avatar
1955 16' Bubble
Europe , glous
Thank you Frank,
I was looking closer today at the profiles in my barn and picked up on what you mentioned between years and factories. There are indeed many different types of beads so I will start experimenting.
Many thanks all.
Sam.
Sam
Old 10-24-2011, 01:51 PM   #12
I have searched for the thread, but the tool is two bearing mounted to handle. The angle you hold it and the pressure you exert will affect that crease you note at the edge.
Old 10-24-2011, 04:52 PM   #13
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
These pics
ID:	143586   Click image for larger version
ID:	143588   Click image for larger version
Old 10-24-2011, 04:54 PM   #14
1960 33' Custom
may help
Not sure if this'll help at all but this is one of ours at the shop. The lower cylinder is compressible material. The palm sized version is handy too if you are working solo.
End cap repair pdwhitt Upholstery, Blinds, Walls & Interior Finishes 1 08-02-2011 10:21 PM
Mounting A TV to End Cap star kitty Audio, Video & TV 7 02-07-2011 08:14 AM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
Aluminum end cap? Breadbug General Interior Topics 1 01-27-2011 09:54 AM
Keep or not? Interior end cap. Breadbug General Interior Topics 1 01-18-2011 04:42 PM
