Old 11-23-2010, 11:07 AM   #29
1973 31' Excella 500
Spring Green , Wisconsin
Originally Posted by DanB View Post
Ain't no football in the world that caused that dent, unless it was filled with concrete.
It looks like it spans a seam and is "well defined". I doubt suction cubs are going to work here.
Plus the interior endcap is cracked? That is one heck of a hit! Considering you cap is already damaged. I'm wondering if you might consider cutting a hole big enough to get your hand in and push that dent out?
The repair to the plastic could be done very well with the right material and time. It certainly won't disappear, but should look OK.
Yes the dent does span a seam. I didn't think suction cups would work so that's why I thought it would be better to repair it from the inside. The crack in the endcap is near the bottom street side corner and I don't believe it was the result of the "football" incident.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 11-23-2010, 11:33 AM   #30
Same one as I posted and still @ $200...
I think I am gonna make one!
As far as spanning the seam goes... Look at post #2 in this thread from Funkill... It can be done!
Old 12-19-2010, 07:38 PM   #31
The galley vent panel on my 345 M/H was a mess...
I forgot to do a proper "before pic" so here is a zoomed...
It should match the body panel, but it was bent and flattened, and had a deep gouge across the length..
I pulled it off, and decide to try to make it better... it could hardly be worse!
I stripped the sealing foam off the back and set to it with a body hammer and dolly.... gently eased it back into shape..
A few hours of gentle work and I was pretty happy with it... A long way from perfect, but better than before.
I decided to polish it out...
End result...
Old 12-19-2010, 07:48 PM   #32
Central , Mississippi
How about this? all ya gotta do is completely remove the insides and gently push out the dent
http://www.airforums.com/forums/f109...ome-71609.html
ID:	117355   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-30-2011, 10:47 AM   #33
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Back in May I posted my before photo without an after photo. The windows are not back in but this is my after photo. The dents are gone. And here is the after photo
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 01-30-2011, 10:50 AM   #34
BradS's Avatar
1957 26' Overlander
Images: 14
oops I for got the photos
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-08-2011, 06:19 PM   #35
1993 34' Limited
North Little Rock , Arkansas
What is a suction cup glass carrier?-thank you-kay
kaykeywest is offline   Reply With Quote
Old 02-08-2011, 06:21 PM   #36
1993 34' Limited
I have a dent in the front endcap=don't know how it got there-don't like it-kay
Old 02-08-2011, 06:27 PM   #37
1993 34' Limited
Woohoo-All of a sudden I went from new member to 1 rivet member.
Old 05-26-2011, 12:19 PM   #38
whitsend's Avatar
1954 25' Cruiser
Kyle , The Republic of Texas
BradS - Beautiful work!!
I love that old time rock & roll.
whitsend is offline   Reply With Quote
Old 05-27-2011, 12:34 PM   #39
1993 34' Limited
What tools-Suction?, glue pads-I now have hail dings and a definite dent front, top-have no idea where that came from-please advise-k
Old 05-27-2011, 01:00 PM   #40
Splitrock's Avatar
Sioux Falls , South Dakota
I removed the inside end cap to expose the rear panel dent that came with the trailer. It wasn't near as bad of a job as I had imagined. I got it down by myself with no problems.
I'll take advantage of the opportunity to reseal the inside seams and rivets that I've exposed.
Below, the dent is visible.
I am using two jacks to push a basketball sized tree fall dent out of one end panel.
There was a shadow of a seam that I rolled out with a laminator's end cap roller. It worked pretty well. The roller had a radius side that allowed my rolling to stay soft on the edge. I used heat from a heat gun. My target range was 450 degrees.
The original view of the dent . . .
The dent pushed out with the jacks.
I'm pretty happy with the way it pushed out. A casual observer wouldn't ever know there was a dent there.
Old 05-31-2011, 06:36 PM   #41
DKAir's Avatar
2003 30' Classic S/O
Battle Lake , Minnesota
Really well done, Split Rock. Thanks for the pics and details!
-DK
AIR: 48965
TAC: MN-7
DKAir is offline   Reply With Quote
Old 06-25-2011, 08:43 AM   #42
1973 31' Sovereign
Marshall , Missouri
Vacuum Repair
This is the best picture of the damage that I currently have. Large dent in the upper right. I was wondering, has anyone tried to use vacuum to remove a dent. I have a 36" galvanized wash tub. I was thinking of using some rubber 1/2" copper pipe insulation to go around the rim to form a rubber seal. Then using a holesaw to make a hole in the bottom. Attach the wet/dry vac and let pressure diffrential do the work. I'm assuming that the steel washtub is srtonger than the aluminum skin of the camper. Am i kiddiing my self or will this actually work?
Salvidordali is offline   Reply With Quote
Where to Post a lot of pictures?? THEPILL All Argosy Trailers 9 01-02-2010 01:19 PM
How to post pictures jack simons Forum Admin, News and Member Account Info 1 11-04-2003 05:58 PM
Deletion of Sale Post and Pictures winner Forum Admin, News and Member Account Info 7 05-04-2002 06:15 PM
How to include multiple pictures in a post! PeterH-Airstreamer Forum Admin, News and Member Account Info 1 02-23-2002 10:36 PM
