Old 02-21-2012, 08:50 PM   #1
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
Popped rivet near the top door
I got on this thread hopping to learn. I have noticed a popped rivet near the top hinge side of my door. Is this something common? Is it important to fix before I take another trip?
Why settle for anything less?
1995 34ft Classic Excella 1000
2012 Kings Ranch F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
Old 02-21-2012, 09:22 PM   #2
1973 31' Excella 500
Marysville , Washington
This could be a symptom of the trailer not getting a smooth ride. I would assume that the axles are good on a 1995 so I would check that the wheels are properly balanced. Yes, I know the guy at the tire store said it doesn't matter on a trailer. Do you have load range E tires on a trailer that should have load range D?
Not Done is offline   Reply With Quote
Old 02-21-2012, 09:38 PM   #3
Hodum's Avatar
1995 34' Excella
Yes, load range E. They were brand new just over a year ago when I bought the trailer and the previous owner was very proud of the fact that they were load rang E and he had the maximum air psi (80) in them. I didn't know the difference until I read the service manual and then lowered the air to 50 psi for a smoother ride. When the tires need replacing I definitely will be getting some more flexible ones.
TAC # MS-8
Old 02-21-2012, 09:53 PM   #4
I didn't mean to imply that you shouldn't have load range E. I just suggest that the trailer should have what the trailer should have and they should be balanced. 34', does that have 6 tires? What is the gross weight? I think its Goodyear that publishes a tire pressure by weight guide. They call it something else...
The Airstream Scam Revealed MORA Off Topic Forum 59 01-18-2015 07:50 PM
Beige interior rivet replacements perryg114 General Interior Topics 18 04-02-2012 06:36 AM
Problem w Gaskets on rear door storage access starcraft Exterior Storage Compartments & Access Doors 5 02-23-2012 04:16 PM
I have adjustable rivet gun starcraft Ribs, Skins & Rivets 3 02-22-2012 05:48 AM
Best rivet choice? daved20319 Ribs, Skins & Rivets 3 01-18-2012 01:54 PM
