Old 11-19-2010, 04:06 PM   #1
bennyg's Avatar
1973 23' Safari
New Albany , Indiana
Pop rivets staying on bit during removal
does anyone have a tip for removing pop rivets? i am removing a lot of the interior rivets and i wind up with rivet heads on 1/8" drill bit and i have to stop and remove all the heads off drill bit before i can start again. Thanks
bennyg is offline   Reply With Quote
Old 11-19-2010, 04:08 PM   #2
x
XXXX , XXXX
Yeah Benny they'll do that. Use A pair of pliers to grab the rivet heads and put the drill in reverse to easily remove them.
wasagachris is offline   Reply With Quote
Old 11-19-2010, 04:16 PM   #3
Images: 59
I like to see how many I can cram on a single bit. I think my record was 19.
Old 11-19-2010, 04:22 PM   #4
bennyg's Avatar
1973 23' Safari
Thanks guys
Old 11-19-2010, 05:43 PM   #5
x
XXXX , XXXX
Markdoane you could use a 2ft long bit and try for the Guiness Book of Records. However you would also hold the record for the most holes in an Airstream. LMAO
Old 11-19-2010, 05:56 PM   #6
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
Yup. Keep the pliers handy. It's tough on bare fingers. Look at the bright side, at least you don't get carpul tunnel injury until you put all those rivets back in again with a hand rivet tool.
Cosmos
cosmos is offline   Reply With Quote
Old 11-19-2010, 06:01 PM   #7
Splitrock's Avatar
Sioux Falls , South Dakota
I use a claw hammer. I stick the bit in the claw and reverse drill. Fast!
Old 11-19-2010, 06:19 PM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
grandkids
Old 11-19-2010, 07:03 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Cosmos
That is why they invented power rivet guns
Aaron
WBCCI #XXXX AIR #2495
Old 11-19-2010, 08:21 PM   #10
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
wahoonc is right, when you get ready to put things back together the air rivet gun from Harbor Freight a must have. Installation will go 4 or 5 times faster and you won't be taking ibuprofen because your hands ache at night.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-19-2010, 08:36 PM   #11
Images: 59
Aaron
Ditto. One of the best purchases I made.
It's just so much easier to hold things in position and pull the trigger.
Old 11-19-2010, 09:34 PM   #12
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Wobble the drill a bit when you first start to drill out the rivet. The heads then come off the bit much easier.
Sam
samb is offline   Reply With Quote
Old 11-19-2010, 09:47 PM   #13
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I use a sharp putty knife. One sharp tap and the rivet head is gone. No marks or mars.
Old 11-20-2010, 08:37 AM   #14
Splitrock's Avatar
I tried cutting the heads off with a hammer and chisel and that did work good . . . but the chisel method required two hands and using that method involved me removing the hand previously used to hold up my pants. During the initial test of the rivet chisel method, my pants fell down.
I found the only way to proceed with the chisel was to solicit the help of another person to hold up my pants while I held the hammer to the chisel. We were filming a documentary at the time and due to an unfortunate camera angle, it looked like we were doing something else. After some time of reflection, I returned to drilling off the heads.
Closed End Pop Rivets vhord Ribs, Skins & Rivets 18 05-29-2010 10:04 PM
Pop Rivets For Bumper tgh97531 Ribs, Skins & Rivets 2 01-22-2010 06:59 AM
What size drill bit for the 1/8 inch in pop rivits? TBKP's Overlander Ribs, Skins & Rivets 3 07-24-2003 11:21 AM
