Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 02-02-2015, 06:42 PM   #1
1978 Argosy 24
MooreHaven , Florida
Patch material ???
I have a couple of damaged places on the side pieces of the under belly that i would rather just put a new piece in than trying to repair the original.
The original measures about .020 thick,i looked on Aircraft Spruce and they have several different grades.Question is what grade should i use?
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 02-02-2015, 06:55 PM   #2
1972 25' Tradewind
McHenry County , Illinois
Checked the manual for my '72. I suspect the belly pan is the same for all years of this vintage.
The spec is 3004 aluminum, 0.024" thick.
I've used sheets from the hardware store with Tempro on the rear pan with no problems.
Tom
Tom Nugler is offline   Reply With Quote
Old 02-03-2015, 05:00 AM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
I purchased my belly aluminum from Airparts in Kansas City. Nice folks to deal with, and you can order on line.
They sell a lot of aluminum sheeting, especially to aviation enthusiasts and Airstream restorers. They recommended 5052 H32 at .025 thick for belly pans. It is cheaper per foot, and easy to work with. I did both my 66 and 86 belly pans with this material, no problems noted.
It's my observation that the belly pan is not a structural member of the semi-monocoque construction. The belly pan provides a cover for the floor insulation and makes the trailer a bit more aerodynamic. The belly pan does do an admirable job of holding in moisture so or frames will rust faster.
David
Old 02-03-2015, 06:38 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Just go to any local sheet metal shop and get some aluminum sheet. They won't have 2024.....get whatever...its the belly pan, right? If it goes in the wrap areas try 5052 .030 ....it will polish up for you if needed.......the shop will (can) cut it to size for you too. You avoid freight this way too.
Old 02-03-2015, 04:39 PM   #5
1978 Argosy 24
Thank for the help, i didnt find anything near where i live,now its just a matter of seeing who has the best price online.
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
Wanted: A/S clothing patch tin can luv Commercial Listings 6 03-10-2004 08:33 PM
Water line patch, or factory? TomW Fresh Water Systems 5 12-29-2003 10:14 AM
How do you patch Bullet holes? 59toaster Ribs, Skins & Rivets 5 10-26-2003 08:08 PM
