Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-18-2016, 03:29 PM   #1
Davadar's Avatar
2005 19' Safari
2010 30' Flying Cloud
Langton , Ontario
Paintless dent removal
Can this be repaired using paintless dent removal method? Any other suggestions. Click image for larger version
Name:	ImageUploadedByAirstream Forums1463606916.715418.jpg
Davadar is offline   Reply With Quote
Old 05-18-2016, 03:31 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Hot glue... learn to do yourself!
Old 05-18-2016, 03:52 PM   #3
Davadar's Avatar
2005 19' Safari
Langton , Ontario
That's my plan for this weekend,but some say it can't be done. I hope that I can get it so that it's barely noticeable. I'm not expecting brand new.
Old 05-18-2016, 03:57 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I have had dings worked out of steel with great sucess. The guy had to have access from the back, though.
I bought a hot glue kit. I never successfully removed a single door ding.
CRH is offline   Reply With Quote
Old 05-18-2016, 04:25 PM   #5
Davadar's Avatar
2005 19' Safari
Langton , Ontario
Why? What problems did you have?
Old 05-18-2016, 04:37 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It MIGHT require access from the back, but I THINK that the panel will come out very near clean if you can get it back out without making a crease.
The metal I don't think is stretched very much, and I am about sure that there is no underlying structure there AT ALL.
It is just "crowned" the wrong direction right now.
Superat stultitia.
Old 05-18-2016, 06:36 PM   #7
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I bought a pneumatic dent puller from Harbor Freight to use on a pretty bad dent on the upper rear panel on my '90 Excella.
http://t.harborfreight.com/pneumatic...ler-69718.html
Look for it on sale - I think I paid a lot less than the listed price.
Took a little effort, but I was very pleased with the results - it removed perhaps 95% of the dent. Not perfect, but almost unnoticeable. I intend to take another pass at it.
Good luck!
Cheers,
John
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 05-18-2016, 07:48 PM   #8
"Cloudsplitter"
It worked for our Safari....
I would, let your grass grow 6"....take it off, get a Long Neck B-bottle and roll the panel slowly, gently and carefully in the grass, a holding helper is a good idea.
Not perfect but much better.
Old 05-18-2016, 08:43 PM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
The tab always came unglued before the metal was pulled enough to make a difference.
Old 05-18-2016, 09:45 PM   #10
Davadar's Avatar
2005 19' Safari
Langton , Ontario
Good luck!
Cheers,
John
Did you heat the panel up first?
Old 05-18-2016, 10:54 PM   #11
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
No, I didn't heat it. I was worried about stretching or warping.
John Audette
Old 05-19-2016, 06:45 AM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I had some success on two different Airstreams using an auto body Suction Puller. Just a large rubber suction cup with a handle on it. Surprised one owner when I offered to repair his dent. It worked quite well.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-19-2016, 07:11 AM   #13
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
The point I see that is common in all the comments is the result of paintless dent removal will not be 100% perfect. I see your main decision will be what is the priority low cost or returning the Airstream to the condition it was in before the accident.
TRIPPPIN is offline   Reply With Quote
Old 05-19-2016, 08:28 AM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I think you'll be pleased with the hot glue. It's better than living with a dent and better than the invasive ness of replacing the panel!
Old 05-19-2016, 09:08 AM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
A professional paintless dent repair guy would only charge $100-$200.Why would you even mess with it?.They may need access behind the dent but they will advise you when they look at it.
Old 05-19-2016, 10:21 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If they need access, they may elect to remove the inside panels, OR they may elect to drill small holes in inconspicuous areas inside of the trailer to insert tools.
I am sure they will talk to you about an agreeable process.
Superat stultitia.
Old 05-22-2016, 03:47 PM   #17
Davadar's Avatar
2005 19' Safari
Langton , Ontario
A guy 10 minutes down the road, who works at an auto manufacturing plant repairing dents in new cars used a pneumatic puller to remove the dent in the panel. It's barely noticeable. The stone guard didn't turn out as well but I can live with it and it would be a lot easier to replace than a panel. Click image for larger version
Name:	ImageUploadedByAirstream Forums1463953649.647437.jpg
Old 05-22-2016, 04:07 PM   #18
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Fantastic. I'm glad it worked out for you.
SeaLevel is offline   Reply With Quote
Old 05-22-2016, 06:43 PM   #19
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
The panel looks great! And I dig the Gerry Cheevers mark you decided to go forward with on the stone guard 😀
Old 05-25-2016, 08:14 PM   #20
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
For anyone interested, here's where you go for the tools. Good YouTube on the subject also. I'm going to work on several places using the mini dent puller. Two dents and the puller/supplies are paid for.
Howard L. is offline   Reply With Quote
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Airstream Dent removal & Polishing Shimmer Cleaning, Stripping & Polishing 6 01-01-2012 11:36 AM
Dent Removal Steve Heywood Ribs, Skins & Rivets 21 06-18-2005 07:51 PM
Dent Removal/Hurricane damage ASFlorida25 Ribs, Skins & Rivets 11 11-18-2004 06:19 AM
dent removal nevisstudio Ribs, Skins & Rivets 8 01-14-2004 12:45 PM
