Old 05-19-2016, 10:08 AM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
A professional paintless dent repair guy would only charge $100-$200.Why would you even mess with it?.They may need access behind the dent but they will advise you when they look at it.
Old 05-19-2016, 11:21 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If they need access, they may elect to remove the inside panels, OR they may elect to drill small holes in inconspicuous areas inside of the trailer to insert tools.
I am sure they will talk to you about an agreeable process.
Superat stultitia.
Old 05-22-2016, 04:47 PM   #17
Davadar's Avatar
2005 19' Safari
2010 30' Flying Cloud
Langton , Ontario
A guy 10 minutes down the road, who works at an auto manufacturing plant repairing dents in new cars used a pneumatic puller to remove the dent in the panel. It's barely noticeable. The stone guard didn't turn out as well but I can live with it and it would be a lot easier to replace than a panel. Click image for larger version
Name:	ImageUploadedByAirstream Forums1463953649.647437.jpg
Davadar is offline   Reply With Quote
Old 05-22-2016, 05:07 PM   #18
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Fantastic. I'm glad it worked out for you.
SeaLevel is offline   Reply With Quote
Old 05-22-2016, 07:43 PM   #19
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
The panel looks great! And I dig the Gerry Cheevers mark you decided to go forward with on the stone guard 😀
SteveSueMac is online now   Reply With Quote
Old 05-25-2016, 09:14 PM   #20
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
For anyone interested, here's where you go for the tools. Good YouTube on the subject also. I'm going to work on several places using the mini dent puller. Two dents and the puller/supplies are paid for.
Howard L. is offline   Reply With Quote
Old 05-25-2016, 09:15 PM   #21
Howard L.'s Avatar
San Antonio , Texas
Well, forgot to post the link. DA me.
https://www.dentcrafttools.com/
Old 07-07-2016, 02:58 PM   #22
1963 22' Safari
Hillsville , Virginia
My safari was damaged in a windstorm by a flying tarp styructure. Bent 2 curved panels on roof in front. dents mostl;y on the seam between thetwo panels. can I do anything aobut this with a suction cup/
billyxmas is offline   Reply With Quote
Old 07-07-2016, 05:56 PM   #23
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Refer to my recent post to see how I removed a dent. Not sure it will work for you.
Old 07-07-2016, 07:34 PM   #24
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Originally Posted by AtomicNo13 View Post
Hot glue... learn to do yourself!
Could explain how this is done?
Gary
Castaway is offline   Reply With Quote
Old 07-07-2016, 07:44 PM   #25
Tin Man
LY007's Avatar
1983 27' Excella
Charlottesville , Virginia
I got hit with a shopping cart with an expensive car some years ago. I was skeptical of PDR but they only wanted $50 vs about $500 for repair and paint, so I thought what the heck - if it doesn't work I'm only out $50. I dropped it off and headed for a coffee shop. Before I could take my first sip they called and said they were done. It was a flawless. Definitely my goto guys now.
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
Old 07-07-2016, 07:46 PM   #26
Tin Man
LY007's Avatar
1983 27' Excella
Gary
They hot glue a stud to the car, and then hook a weighted pull tool to the stud. Then they have a chemical that dissolves the glue withou messing up the paint. You can buy a kit on eBay to do this. You tube videos.
Steve
83 Excella 27
07 Tundra Limited
Old 07-08-2016, 07:50 PM   #27
Moflash's Avatar
Paintless dent removal
Foolish to try this yourself as if you mess it up ( and you will ) the pros who charge very little will not be able to repair your work.
Aluminum does not have the memory that steel does.
Old 07-08-2016, 07:55 PM   #28
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I have had 100% success on all vintages of Airstream and several aluminum bodied painted automobiles. Never ruined anything nor pulled off any paint. What can you loose? You already have a dent!
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 02:48 PM
Airstream Dent removal & Polishing Shimmer Cleaning, Stripping & Polishing 6 01-01-2012 12:36 PM
Dent Removal Steve Heywood Ribs, Skins & Rivets 21 06-18-2005 08:51 PM
Dent Removal/Hurricane damage ASFlorida25 Ribs, Skins & Rivets 11 11-18-2004 07:19 AM
dent removal nevisstudio Ribs, Skins & Rivets 8 01-14-2004 01:45 PM
