Old 12-24-2004, 04:52 PM   #1
Tinsel Loaf's Avatar
Question Exterior finish paint vs clearcoat and more..
What is the new Airstream coating made of and where can I find some.
I must clean the existing new style coating off a panel and do a re-spray. What is the best chemical to remove the new type of coating and do I use a airless spray unit to reapply the coating.
Oh by the way donít leave your keys in the dead bolt lock and have the wind catch the door and slam it open. It leaves a dent ( beauty mark ) in the panel.
Tinsel Loaf is offline   Reply With Quote
Old 12-25-2004, 07:14 AM   #2
Since, I believe, late 1999 the clearcoat finish has been applied to the sheet alumium by Alcoa in their plant. The finish cannot be duplicated even by Airstream at the factory.
I hope someone on these forums knows how to strip off the original clearcoat, or at least knows if it is possible to remove chemically. If not, your only recourse is mechanical - sanding, polishing, etc.
Mark
Old 12-25-2004, 07:27 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The stuff is called Plasticoat, I have tried several methods for stripping, with mixed results. Laquer thinner, Acetone, brake fluid, and oven cleaner. The oven cleaner basically softened the coating so it could be more easily removed manually. Just make sure you rinse it off well. The same product comes in spray cans marketed as paint and gasket remover. The brake fluid does to the Plasticoat the same thing it does to automotive paint, leave it on a long time, and the coat will pucker up and peel off. It is alcohol based, so it will rinse off with plain water. Laquer thinner and Acetone are petroleum distillates, and cannot easily be rinsed off. They also tend to evaporate quickly.
There is also a product called Aircraft Stripper, it is supposed to remove paint from aluminum, but I have only 2nd hand experience with it, and can't personally vouch for its effectiveness.
Old 12-25-2004, 01:34 PM   #4
The new type clear coat, is not available to anyone, not even Airstream.
The best stripper to use for the old plasticoat is "Aircraft Stripper." It costs a little more, but does a fast supurb job.
A word of caution. Any stripper will attack plastics. Therefore all the plastic exterior components must be removed.
We have used it for over 15 years.
Old 01-25-2005, 06:03 PM   #5
doh
doh's Avatar
1999 25' Safari
Manchaca , Texas
New "Alcoa" finish started...
The new Alcoa finish started about 144 units before 15 December 1998 -that's the DOB of my 99 Safari SN 512756.
Per the 1999 Safari parts manual, page I-3 - all trailers after SN 512612 have the Alcoa finish. My understanding is that the SN's are not model specific but issued to each unit (whatever it is) as they are produced, #613 could have been a 34' Classic or whatever.
Since that time there have been customers with experiences similar to the
previous Plastic Coat. Reportedly, the process was fully debugged around 2002.
Prior to that - some were good and some were not so good. Mine seems to be one of the good ones, or better ones - a little peeling above the front window - 1" perhaps in places - so far. I have seen some with rather severe peeling on the sides - exposure to the sun while stored may be a significant factor.
My understanding is that it "is" Plastic Coat - applied at the Alcoa plant, under better controlled conditions. It is a 2 part mix and apparently relative humidity is a critical factor with mixing and application.
I would think that the process of stripping and re-applying is the same - regardless of which 'type' of finish it is.
The key difference is that the rivets, window, door frames, etc., are not coated.
Now - Andy is the expert - only an insane (or incredibly stoopid) person would challenge his knowledge & resources. He may find fault in some of my assumptions & I gladly accept any critique Andy has. That's how we learn the truth in this forum.
& @#$% I just noticed Andy's last post on this thread was on Christmas day - We really appreciate your dedication Andy- but get a life
WBCCI 1845
doh is offline   Reply With Quote
Old 01-25-2005, 07:06 PM   #6
doh.
You have the new style plasticoat, or clear finish, down perfect.
Long term will tell us about the uncovered surfaces.
We have a 2005 in the shop, and I checked it out, and it's as you pointed out. No protective paint on the window frames, door frames or rivets.
Originally they used anodized rivets, but it appears thats a thing of the past.
Hey guys, I do have a life. It's just a different kind.
I get mucho work done on weekends etc, when we are closed.
But when your working, at least as often as I can, I am enjoying the beach, the swaying palm trees, the people and their culture, in ........................... Hawaii, in particular, Oahu.
Ah yes, what a beautiful place to goof off. And the best part is that my wife enjoys it too.
Sure beats southern California, at least where we live.
At last count, there are 3 Airstreams there. But I never tell them when I will be visiting.
Old 01-26-2005, 11:45 AM   #7
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Talking
Curiously enough, Airstream Life magazine also has three subscribers in Hawaii. I always wondered if they were owners, or just admirers.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 01-26-2005, 02:54 PM   #8
Arrow Old finish removal
Our '71 Safari has an panel beside the entry door under the window that has the remains of several old decals and stickers. I would like to refinish that panel. How best to remove the old finish and what to respray with?
Dan
Dbraw is offline   Reply With Quote
Old 01-26-2005, 03:11 PM   #9
Dan.
Very carefully remove the remains of the old decals, etc.
You can use Aircraft stripper or lacquer thinner.
Rub with the grain, only.
You can refinish that small area with a spray can of plasticoat.
Some Airstream dealers carry that paint.
Old 01-26-2005, 03:58 PM   #10
Andy,
Thanks for the info. If I decide to do a larger area, like the door, can I buy Plasticoat in a larger size than a spray can? Is Glisten PC coating something that you would recommend?
Dan
Old 01-26-2005, 04:00 PM   #11
I would first try scraping off the decals with gentle heat (hair dryer, not heat gun) and wooden scrapers. You can make them by beveling the end of craft sticks. Then I'd clean up the residue with xylol. But beware - read the warnings on the can. It is nasty, dangerous stuff.
This should leave any remaining original coating still intact.
Mark
Old 01-26-2005, 04:56 PM   #12
Dan.
The only clear finish that we recommend is the plasticoat that Airstream uses either in spray cans, or by the gallons.
Old 01-26-2005, 06:18 PM   #13
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
Unhappy where to buy the touch up airstream spray
Be careful where you buy the touch up. We pd. $18. for shipping two regular size spray cans (not told about this high shipping cost ahead of time), plus the $17. each can, a total of over $50 for two cans.
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 01-28-2005, 09:43 PM   #14
2005 30' Classic Slideout
Boise , Idaho
Dan.
Andy,
I haven't been reading these forums very long, but long enough to echo what others have said - your help is greatly appreciated.
I have used an Airstream spray can product called RV CLEAR ACRYLIC, Part No. 28174W to touch-up the clearcoat on our 98 Safari. Is this the plasticoat that you are referring to?
Earl
EKBrace is offline   Reply With Quote
Cleaning Agent (Aluminum Exterior) Cat Cleaning, Stripping & Polishing 20 10-09-2012 05:44 AM
Exterior Finish Questions-85 Excella Kirby Stone Cleaning, Stripping & Polishing 2 10-21-2002 05:27 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Window sills (painted or bare aluminum)? Andy R Windows & Screens 2 06-04-2002 01:01 PM
