Old 11-25-2007, 08:34 AM   #85
1973 25' Tradewind
Orange , California
The AS website cliams that white paint is used on new trailer roof panels to reduce the interior temperature by "7 degrees". Can anyone confirm this? I live in the Southwest, and the heat load can be oppressive.
amlie is offline   Reply With Quote
Old 11-25-2007, 10:19 AM   #86
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
My '97 Excella from "Cronology of Painting My Excella" fame has a factory painted white roof and yes, white absorbs less of the solar energy making it cooler.
On this thread I've read a lot about Plasticoat being the only clearcoat for aluminum. I may have an alternative. Last winter I had a brainstorm and invented the item shown below. To finish the aluminum components, I first did an alumiprep wash, then did a CLEAR alodine conversion coat (available from Aircraft Spruce, Inc.), then I painted it with clear Imron. Most people do not know that Imron starts out as a clear base then pigments are added to it to achieve the desired color. I used the clear base with no pigments. So far, the Imron is doing great, and it has a very near match to Airsteam clearcoat. Some people may not know it, but Imron is one of the few products which retains it's color over a long life with almost no yellowing. Where other linear urethanes yellow over time, Imron does not.
Durability? Time will tell, but it's doing fine so far.
ID:	49872   Click image for larger version
ID:	49874   Click image for larger version
So Long!
Bob Thompson is offline   Reply With Quote
Old 11-25-2007, 12:05 PM   #87
Images: 67
For the record, I don't think the clear Imron would work on polished aluminum. I am convinced it needs a "texture" to "lock into" to keep from peeling.
So Long!
Cleaning Agent (Aluminum Exterior) Cat Cleaning, Stripping & Polishing 20 10-09-2012 05:44 AM
Exterior Finish Questions-85 Excella Kirby Stone Cleaning, Stripping & Polishing 2 10-21-2002 05:27 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Window sills (painted or bare aluminum)? Andy R Windows & Screens 2 06-04-2002 01:01 PM
