Old 03-25-2008, 01:35 PM   #1
Breiz's Avatar
1977 29' Ambassador
Latrobe , Pennsylvania
Unhappy Ouch! Skin damage
While looking at our newly purchased 1977 Ambassador last weekend we found a disturbing hole in the skin. It is in the roof over the front curbside vista view window. It looks like something had been mounted there before and was torn out resulting in a large hole and the window seems bent. I've included a pic for reference. Anyone know what might have been attached there? How do I repair the hole? What do I do about it being pulled away from the window? Thanks for any advice!
Breiz is offline   Reply With Quote
Old 03-25-2008, 01:37 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Looks like a Zip-Dee window awning with the extensions. One of the extension mounts could have been mounted there.
Old 03-25-2008, 07:17 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
First off I would get it sealed up while you make up your mind as to a repair. Can you get access to the inside? If it were mine I would remove the vista view to see if it can be repaired, straightened, etc. A external repair doubler for the shin should repair the tear out. Do you have any sheet metal experience or know someone that does?
Old 03-25-2008, 07:49 PM   #4
Well Preserved
1993 21' Sovereign
I see 3 screws in that area, they can at least temporarily rivet a small patch over the area until they make a decision about what they want to do there. It will keep the water out of the wound.
Old 03-25-2008, 07:56 PM   #5
1973 25' Tradewind
Romulus , New York
silicone it for now. real easy to pull out later.
jayray5 is offline   Reply With Quote
I need to repair damage to the aluminum skin on my 345 MH. Mr. D Mechanics Corner - Engines, Transmission & More... 5 05-01-2007 07:46 AM
skin damage by hydrant Astrodokk Ribs, Skins & Rivets 7 12-20-2006 10:00 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Ouch !! airstreamcaravel Off Topic Forum 6 05-27-2004 03:33 PM
Ouch!! dtbw 2003 Safari 7 09-17-2003 06:29 PM
