08-16-2007, 01:23 PM
1964 24' Tradewind
dousman
, Wisconsin
On back of TW - What is this?
Greetings All,
On the back of the Tradewind, directly above the access hatch, there is this. Have seen them before - just never knew what they were. What is this?
Karol
08-16-2007, 01:26 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Its hard to tell, but I wonder if it is a light fixture.
08-16-2007, 01:27 PM
2003 22' International CCD
Kiln
, Mississippi
Originally Posted by campngirl
Greetings All,
On the back of the Tradewind, dirrectly above the access hatch, there is this. Have seen them before - just never knew what they were. What is this?
Karol
Is the 12V battery in there? Looks like a vent hole for the battery housing. On some models the battery is in a box and has a cover - it needs to off gas and those gases are explosive (hydrogen) - there should be tubing from that box to that hole in the skin to allow the gases to escape to the outside.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
08-16-2007, 02:07 PM
Colville
Clancy_boy called it right!
I have the same thing on the back of my Overlander. I had the same question and Fred ( 47WeeWind) was able to identify it for me as the vent hole for the battery. Mine leaked, so a small bead of vulkem along the top of the lip solved that issue.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
08-16-2007, 02:29 PM
2012 25' FB Eddie Bauer
Virginia Beach
spoiled my fun..
I was going to ask if it was a rear bath unit and if another kind of "gas" might vent from there.
Or perhaps it was for a backup camera... what? they didn't have them back then?
Or "well dummy don't you HAVE a license plate on your trailer?"
It's THURSDAY and I like my Airstream because it's pretty and silver and I got my Zip Dee helper handles installed which makes setting up the canopy soooooooooooo easy.
Paula Ford, living in Air
08-16-2007, 03:46 PM
1964 24' Tradewind
dousman
, Wisconsin
Greetings,
Thanks to all for the quick input.
The license plate light/ bracket is higher and centered under the rear window... so nope, not for the tag. This is right above the access hatch more toward the curb side .
The battery (old/dead) is back there, has a cover on the top, not in a box...... but I bet it was at one time. No hose to the now identified vent either. I couldn't tell what that thing was. A po has put a little brass plug in it.
Now, its new battery box and proper venting before a new battery.
(and removing the little brass stopper)
Again, many thanks.
Love this forum.
Karol
08-17-2007, 10:34 AM
Corona
Greetings All,
Karol
The original installation of the battery, used a plastic cap on top of the battery.
A clear plastic hose connected the cap to the vent hole on the exterior, as you show in your photo, to allow the gas from the battery to vent outside instead of within the trailer.
08-17-2007, 12:29 PM
1966 24' Tradewind
Placerville
Waddyaknow.
Yes, you learn/discover sumtin new every day. I have the same thing on my '66 but I never noticed the hole under the lip. We've had this TW for 16 months TOO!
Andy,
Our battery is anchored el natural to a tray. Should I consider re-venting the battery or are today's batteries safer?
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
08-17-2007, 01:05 PM
Kiln
, Mississippi
Andy,
Neil and Lynn
I'm not Andy but since I answered the same way above as he did later, I think I can answer this one too.
Yes, you should consider venting any lead acid automotive type battery to the outside. They all give of hydrogen gases during the charging cycle - even the maintenance free types and gel cells. If not for the explosive reasons of having a battery filled with a solution that will easily desolve aluminum if it burps up or boils off the liquid contents to the side skin of your trailer is reason enough to have it inside an enclosed and externally vented case.
One little ground short from a chaffed wire and a compartment full of charging units (old univolt) with hydrogen gas will be enough to do some damage. Back to the old days of checking water levels in the battery with a match.
08-17-2007, 01:41 PM
1964 24' Tradewind
dousman
, Wisconsin
Thank-You all,
I will have to drill out the rivets and remove the brass plug a po had put in the vent, then get a box for the new battery.
Much appreciation.
Karol
08-17-2007, 01:50 PM
1966 24' Tradewind
Placerville
Thank you. Are the vented battery boxes still available or will I have to improvise one? I have not noticed any such boxes when I was searching for a box awhile ago.
Neil and Lynn.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
