Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-16-2007, 02:23 PM   #1
campngirl
campngirl's Avatar
Profile:  1964 24' Tradewind
dousman , Wisconsin
On back of TW - What is this?
Greetings All,
On the back of the Tradewind, directly above the access hatch, there is this. Have seen them before - just never knew what they were. What is this?
Karol
Name:	'64 TW above rear power ctr access- what is this.jpg
campngirl is offline   Reply With Quote
Old 08-16-2007, 02:26 PM   #2
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
Its hard to tell, but I wonder if it is a light fixture.
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 08-16-2007, 02:27 PM   #3
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Originally Posted by campngirl
Greetings All,
On the back of the Tradewind, dirrectly above the access hatch, there is this. Have seen them before - just never knew what they were. What is this?
Karol
Is the 12V battery in there? Looks like a vent hole for the battery housing. On some models the battery is in a box and has a cover - it needs to off gas and those gases are explosive (hydrogen) - there should be tubing from that box to that hole in the skin to allow the gases to escape to the outside.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 08-16-2007, 03:07 PM   #4
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 70
Clancy_boy called it right!
I have the same thing on the back of my Overlander. I had the same question and Fred (47WeeWind) was able to identify it for me as the vent hole for the battery. Mine leaked, so a small bead of vulkem along the top of the lip solved that issue.
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is online now   Reply With Quote
Old 08-16-2007, 03:29 PM   #5
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
spoiled my fun..
I was going to ask if it was a rear bath unit and if another kind of "gas" might vent from there.
Or perhaps it was for a backup camera... what? they didn't have them back then?
Or "well dummy don't you HAVE a license plate on your trailer?"
It's THURSDAY and I like my Airstream because it's pretty and silver and I got my Zip Dee helper handles installed which makes setting up the canopy soooooooooooo easy.
Paula Ford, living in Air
Today is a gift. That's why they call it "the present"
Old 08-16-2007, 04:46 PM   #6
campngirl
campngirl's Avatar
dousman , Wisconsin
Greetings,
Thanks to all for the quick input.
The license plate light/ bracket is higher and centered under the rear window... so nope, not for the tag. This is right above the access hatch more toward the curb side .
The battery (old/dead) is back there, has a cover on the top, not in a box...... but I bet it was at one time. No hose to the now identified vent either. I couldn't tell what that thing was. A po has put a little brass plug in it.
Now, its new battery box and proper venting before a new battery.
(and removing the little brass stopper)
Again, many thanks.
Love this forum.
Karol
Old 08-17-2007, 11:34 AM   #7
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Greetings All,
Karol
The original installation of the battery, used a plastic cap on top of the battery.
A clear plastic hose connected the cap to the vent hole on the exterior, as you show in your photo, to allow the gas from the battery to vent outside instead of within the trailer.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 08-17-2007, 01:29 PM   #8
FreshAir
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Waddyaknow.
Yes, you learn/discover sumtin new every day. I have the same thing on my '66 but I never noticed the hole under the lip. We've had this TW for 16 months TOO!
Andy,
Our battery is anchored el natural to a tray. Should I consider re-venting the battery or are today's batteries safer?
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
Moonrise - Sunset
October 13, 2008
1966 Trade Wind
455 cid
Old 08-17-2007, 02:05 PM   #9
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Andy,
Neil and Lynn
I'm not Andy but since I answered the same way above as he did later, I think I can answer this one too.
Yes, you should consider venting any lead acid automotive type battery to the outside. They all give of hydrogen gases during the charging cycle - even the maintenance free types and gel cells. If not for the explosive reasons of having a battery filled with a solution that will easily desolve aluminum if it burps up or boils off the liquid contents to the side skin of your trailer is reason enough to have it inside an enclosed and externally vented case.
One little ground short from a chaffed wire and a compartment full of charging units (old univolt) with hydrogen gas will be enough to do some damage. Back to the old days of checking water levels in the battery with a match.
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Old 08-17-2007, 02:41 PM   #10
campngirl
campngirl's Avatar
dousman , Wisconsin
Thank-You all,
I will have to drill out the rivets and remove the brass plug a po had put in the vent, then get a box for the new battery.
Much appreciation.
Karol
Old 08-17-2007, 02:50 PM   #11
FreshAir
FreshAir's Avatar
Thank you. Are the vented battery boxes still available or will I have to improvise one? I have not noticed any such boxes when I was searching for a box awhile ago.
Neil and Lynn.
FreshAir #12407
Avatar;
Moonrise - Sunset
October 13, 2008
1966 Trade Wind
455 cid
Back from our Maiden Voyage!! 71Overlander Our Community 12 03-12-2008 08:35 PM
"THE" Letter !!!-Zoning violations discussions airstreamcaravel Title, VIN & Registration 108 01-06-2004 08:41 PM
back up lights john hd Lights - Interior & Exterior 0 12-27-2002 07:54 PM
Very interesting story/ back pack FrankR On The Road... 2 08-31-2002 09:29 PM
test
