Old 07-31-2006, 12:13 AM   #15
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Originally Posted by beckybillrae
I guess I'll order a few Olympic rivets & give it a try. I'm a bit nervous about the smoothing of the head, but I'll give it a shot. Thanks. The link was a nice thing to see & I understand a bit better. Guess all I need is a sanding head for my dremel, since I'm not going to buy the shaver. Thanks again,
Becky
You'll get good at rivet shaving with a Dremel tool, trust me. My first few were awful but the more I did the better I got at it. After I do my polish job you won't know the difference.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 07-31-2006, 03:13 PM   #16
Dan@LED4RV's Avatar
Denton , North Carolina
Exclamation no not remove
Originally Posted by artlink
Hi,
I've picked-up some Olympic rivets at Airstream and noticed little black washers attached. I seem to remember reading something about removing/not-removing them?
I can't remember the thread and couldn't find it in search.
So, remove or not to remove, that is the question?
Thanks in advance,
Uric
It will make it leak if you remove them
Dan@LED4RV is offline   Reply With Quote
Old 07-31-2006, 03:32 PM   #17
Not if you apply some Vulkem or Parbond sealer to the back side of the rivet head.
That is a better seal than the original construction.
It's "GUARANTEED" not to leak, "ever".
Any and all rubber or neoprene washers etc, have a limited life, depending on it's use at how much heat or sun that it has been exposed to.
Washers on Olympic rivets, are a "NO NO".
If you do use them, you will be and in time.
Guaranteed.
Old 07-31-2006, 07:42 PM   #18
1960 24' Tradewind
santa barbara , California
Andy and uwe are right ,don't use the washers ,all the 100s of rivits I have
purchased from inland Rv never had any black washer ,you will have maximum
strength without the seal .I don't know why those have a seal ,as it will
limit the rivits clamping ability .I have bought 3 or 4 100 rivit packs over the
last couple years ,no little seal.
Scott
scottanlily is offline   Reply With Quote
Old 08-02-2006, 06:05 PM   #19
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Need 10 rivets!
WoW heated.
I have removed the o-rings and applied Parabond.
But now I'm short about 10 rivets, can anyone spare to sell 10-15
Michael
ArtStream is offline   Reply With Quote
Old 08-02-2006, 06:09 PM   #20
WoW heated.
Michael
You have an Airstream.
You will need rivets, many times.
Buy a bag of 100 for $20.00 and you will have some spares, "for the next time".
Old 08-02-2006, 06:58 PM   #21
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Scott
Scott,
The Olympic rivets are used for other applications besideds Airstreams. We use the ones with the neoprene/rubber washers in various roofing applications. Typically in conjunction with polymer panels that you want fastened down snuggly but not so tight as to crack. For this application they are great. But as has been pointed out you don't want them for Airstreams.
Aaron
WBCCI #XXXX AIR #2495
Old 08-31-2006, 11:35 PM   #22
Reg
1975 31' Excella 500
Crowley , Texas
Wow you guys really get serious about this rivet stuff!! I am a new owner with lots to learn , so by listening to all of you bat it back & forth I have already learned an answer to my ? in my first post .Am I correct in assuming that I can apply Olimpics with a good hand pop rivet gun? I dont even know at this point what an Olimpic looks like before aplication. Guess I need to find a dealer & buy a few and experiment .
Any of you have any good ideas on how I can remove 1 1/2" of water from between the glass on my curved front wing window??? Thanks Reg
Reg is offline   Reply With Quote
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 07:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 07:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
