Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 03-28-2006, 06:45 PM   #1
minuet7.3
Profile:  1979 Argosy Minuet 7.3 Metre
Thonotosassa , Florida
olympic rivets
Just got a broken window that I need to repair. It is a fixed glazing type next to the door. Does anyone know the Olympic part number for the rivits and where can I get the glazing bead to hold the 1/8 inch lexan in the frame? I called inland today and they dont have the glazing bead. Thanks Curt
minuet7.3 is offline   Reply With Quote
Old 03-28-2006, 06:59 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
Try this place. They have the Olympic rivets, and lots of different glazing beads. http://www.vintagetrailersupply.com/...lts.asp?Cat=26
Non-contributing deadbeat.
Old 03-29-2006, 11:24 AM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Curt.
The original glazing bead is not available, except from Airstream, but they will not sell it.
Using an unproven substitute glazing material would more than likely assure you of water leaks.
Additionally, taking the frame apart is easy. Putting the frame back together, including the hinge, results in a flimsy window that will never seal correctly.
We do have the olympics.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 03-29-2006, 06:45 PM   #4
minuet7.3
Andy, The window in question has no hinge it is a fixed glass window. I talked to your parts lady on Tuesdayand she said that you have the rivets. I plan to order them this week.Is the glazing bead available for the fixed glass window?
Old 03-29-2006, 07:30 PM   #5
Commercial Vendor
We have a glazing bead, but it is not like the original.
It can be used, "IF" your very careful.
Inlandrv.com
800-8777311
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 03:31 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 08:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 08:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 07:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 04:02 PM
test
