Old 03-27-2019, 03:37 PM   #1
1976 31' Sovereign
Helotes , Texas
Olympic rivets??
Are these poorly executed Olympic rivets or large head pop rivets?
Bottom line...PO or dealer installed when front cursed window broke. When I removed interior skin there was ample evidence of leaking; including rotten floor.
IF these are poorly installed Olympic rivets, I can see why some people hate them. It also looks like a poor caulking job as well.
I am not going to take a stick to that hornet's nest, but I don't have a problem with properly installed Olympics.
Greg
glrtex is offline   Reply With Quote
Old 03-27-2019, 03:49 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
They do look like poorly done Olympic rivets. If you can see the backside of the rivets, Olympic rivets have 3 legs which fold out from the body of the rivet to secure them. Buck rivets expand like a mushroom to secure them. If you are going to replace them with buck rivets, you will need to work on them from both sides.
Richard
Old 03-27-2019, 04:55 PM   #3
1976 31' Sovereign
Oswego , Illinois
If olympic they wre not finished properly, when pin is snipped then has to be shaved, these lokk like not shaved or mabe pop rivets, they will leak, proper olympics should not leak, JC uses all most of time for skin repairs. When shaved the pin should not be visible these pins very noticable. IMO very poor sloppy work, I would replace asap. If interior is intact use olympics if open use bucked. I hae used many olympics never had leak & never looked this bad, many people cannot tell I used them.
Old 03-27-2019, 05:05 PM   #4
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Poorly installed Olympic's for sure!! Did not shave correctly. As mentioned prior, you can reinstall Olympics if you don't have interior access, but shave them and you will have no problems. I have installed over 1000 of them and never had a leak. I put a dab of sealant on them when installing as well. Shavers cost money, but well worth owning if you own an Airstream. JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 03-27-2019, 05:32 PM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
If you use Olympic Rivets, many of them come with a rubber gasket. Remove the gasket and use a dab of sealant as stated earlier. The gaskets will break down over time and cause the rivet to not be tight. I have used many of these rivets and never had a problem
Richard
Old 03-27-2019, 08:24 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have used Olympic tri fold rivets. I have had the mandrel break inside the rivet, not beyond the head so you can shave it down. Some say this is due to one of the three little legs hits something inside so the rivet doesn't expand properly. I had to drill out several Olympic rivets on a couple of exterior skin patches because the mandrel broke inside the rivet.
Maybe the folks who did the window repair said heck with it.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
http://www.airforums.com/forums/f221...ct-202081.html
Old 03-29-2019, 11:46 AM   #7
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Your post says you have the interior skin off. That allows you to use buck rivets. Pro's, no shaving, no short mandrel breakoff, stay tight, well sealed, superior strength, cheaper, perfect match better resale. Con's, can't think of one if you have access to the inside for the bucking bar. With that much water intrusion I'd look real close at the mating surfaces / seal between the window frame and exterior skin, & glass and frame.
putback is offline   Reply With Quote
Old 03-29-2019, 12:02 PM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
One downside to the bucked rivet is, one slip and you need a new window.
Richard
Old 03-29-2019, 07:44 PM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Those look like poorly installed Cherrylock rivets. Take a picture on the inside to confirm.
TheSignLadys tips for finding and repairing leaky rivets + Fixing with Olympic Rivets thesignlady Ribs, Skins & Rivets 17 10-17-2017 07:32 PM
Buck Rivets or Olympic Rivets halimer Ribs, Skins & Rivets 5 09-21-2011 04:20 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 09:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 11:00 PM
