Old 05-15-2006, 07:12 AM   #1
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Question Olympic rivet shaver usage
I have installed 600 olypic rivets in restoring a 34' trailer. I have cut the extensions down to about 1/16", when I use the shaver it dances around the extension. How do I use the shaver? Do I need to hit each rivet with a grinder first to remove stub extension? I have plenty of work inside now that outside is watertight and I don't want to ruin the shaver by experimenting. Seems like I missing something in my approach.
HELP!
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 05-15-2006, 07:22 AM   #2
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
Paul,
use the grinder... It will help and make it a lot easier. It is much easier when the extensions are really short!
Then put the shaver tool over the rivet head and bring it to high speed before you lower it. Donīt lower it on the rivet head before you speed up your Makita or what ever you use, that will make the shaver tool bounce.
Good luck and have fun shaving 600 Olympics is a lot of work!!
Bjoern
BjŲrn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just havenīt met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 05-15-2006, 07:28 AM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hi Paul ~
I use a Dremel with the cut-off wheel and take the stub down to just above the domed head of the rivet. Like Bjoern says, place the rivet shaver on the top of the rivet, get the drill up to speed and then push in on the drill while holding the shaver in place with your other hand. I've found that a cordless drill works better than a 110 volt powered one because the battery version isn't as high of an RPM. If you're not using the cordless, try it out.
Best of luck and be patient. It takes a little time to get the hang of it but once you do, those other 595 will look great.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 05-15-2006, 07:37 AM   #4
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Smile
Thanks, I thought that grinding closer was required, but hoped to elimanate that step. I will be using a battery drill. Now to touch up each one with a grinder!
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
How durable is a Cyclo polisher? What about a rivet shaver? Andy R Cleaning, Stripping & Polishing 13 09-13-2011 05:56 AM
Best rivet tool? Andy R Ribs, Skins & Rivets 9 09-24-2006 07:36 AM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
