Old 05-02-2018, 10:16 AM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Olympic Rivet Shaver Cutter
Does anyone know what the threads of the Olympic Rivet Shaver cutter bit are? I'm wondering if I can buy a replacement bit and put it in a microstop, either 1/4-28 or 3/8-24.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-02-2018, 10:24 AM   #2
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I don't have one but would think it is in a collet not threaded in.
Dingo Girl is offline   Reply With Quote
Old 05-02-2018, 10:27 AM   #3
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Oops it says 1/4 - 28 in Google search
Old 05-02-2018, 03:01 PM   #4
Thanks!
I spent over an hour on Google trying to find out. Can you send me the link? I want to figure out how I missed it.
Al
S/OS #004
Old 05-02-2018, 03:21 PM   #5
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
https://www.vintagetrailersupply.com...-p/vts-178.htm
Here you go.
Old 05-02-2018, 03:21 PM   #6
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I put in "rivet shaver bit Olympic"
Old 05-02-2018, 03:23 PM   #7
Clearly order is important. I googled something very similar, but in reverse order.
Thanks again,
Al
S/OS #004
Old 05-03-2018, 03:25 PM   #8
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
Well yes you can put the rivet shaver in the microstop... it comes in 1/4-28 thread... but, if you do ... its critical of the angle... and is why they have larger guides on the drill gun shaver... but, yes I have used the rivet shaver in the micorstop... and it works... just keep it to the surface when spin'n
We do it all the time on aircraft when shooting cherry max's/locks... (brazier ...dome head) for the finish.
Olympic rivets are nice but we use the cherry max ones which have better strength... and look just as good. .. and the stub breaks off right at the surface...locking it with the strength of a regular rivet... and it seals up with little sealant needed ... if any
What ever you do ...DO NOT use pop rivets... they are pure junk... and look ugly with a hole in the center...
We all share one at the airfield... although I have it... you can rent them too...
I would not get it from airstream... aircraft supply , US tools, etc gives you a better quality... if you go for the kits of tools.. but you only need the cutter if you use the microstop...
hope this helps..
G.M>
GM Airstream is offline   Reply With Quote
Old 03-09-2019, 06:25 PM   #9
Laff67safari's Avatar
1967 22' Safari
Zanesville , Ohio
I canít seam to find the correct shaver bit to use in a microstop. Any help would be appreciated.
Laff67safari is offline   Reply With Quote
Old 03-11-2019, 09:31 AM   #10
G-Ranch
G-Ranch's Avatar
1970 25' Tradewind
Smyrna , Georgia
Rivet Shaver
Contact the folks at AirParts, Inc. - KC Kansas - 913-813-1780
G-Ranch is offline   Reply With Quote
Old 03-11-2019, 09:35 AM   #11
1967 22' Safari
Zanesville , Ohio
Wanted 5/32 Olympic rivet shaver, and rivet cutter nicolett25 Airstream Classifieds 0 10-27-2016 09:41 PM
Anyone near central NC with Olympic Rivet Shaver? Adam.Pyburn Ribs, Skins & Rivets 5 02-17-2012 12:33 PM
Olympic rivet shaver walter1 Ribs, Skins & Rivets 1 09-24-2007 10:19 PM
Olympic Rivet Shaver r&kweber Ribs, Skins & Rivets 16 01-30-2007 11:41 PM
Olympic rivet shaver usage airstream4 Ribs, Skins & Rivets 3 05-15-2006 07:37 AM
