Old 02-12-2018, 09:38 PM   #1
Hammond , Wisconsin
Olympic rivet sealing
hey all,
I just ordered 200 Olympic rivets with the neoprene washers. Do I still need to use Trempro 635 on them to make them watertight? I only have a few exterior ones to do but thought I would have a bunch on hand. Was at the RV show this weekend and talked to a guy that repairs Airstreams. He said that the company that made the Olympic rivets just went under and they are getting hard to find. But thinks a new company will be making them soon.
rmojo is offline   Reply With Quote
Old 02-13-2018, 05:06 AM   #2
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Don't use the washers. Tear them off and use trempro.
The neoprene will shrink in time and leak.
Good luck on your project!
Dingo Girl is offline   Reply With Quote
Old 02-13-2018, 07:33 AM   #3
dznf0g's Avatar
Oswego , Illinois
Ditto, remove the washers, use your favorite Polyurethane (recommend a UV formula). After completely cured, use Captain Tolleys Creaping Crack cure to ensure sealing. (go over rest of trailer rivets with Tolley's as well....I use a small suction cup to test rivets for air, and thus, water tightness)
-Rich-
Old 02-13-2018, 08:52 AM   #4
Hammond , Wisconsin
Thanks for the advice!
Wanted 5/32 Olympic rivet shaver, and rivet cutter nicolett25 Airstream Classifieds 0 10-27-2016 10:41 PM
Olympic rivet tools smallfry Ribs, Skins & Rivets 9 10-16-2014 06:37 PM
Sealing olympic rivets airpatton Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 01-27-2013 06:55 PM
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 02:34 PM
Sealing Olympic Rivets From The Inside Dan Clayton Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-13-2006 10:02 PM
