Old 08-09-2011, 10:54 AM   #85
Originally Posted by Aviator View Post
Do the Olympic rivets come in different lengths? If so, what do I need to replace a missing exterior skin rivet on the side of our 'stream?
Craig.
One length does it for any Airstream metal replacement.
Using the standard Airstream length works great.
Old 08-09-2011, 12:13 PM   #86
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
As far as I'm aware, Olympics only come in one length and since they are so unique in their construction and function, I don't believe a different length would be cost effective to make. Once you see and use them, you'll see.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-09-2011, 12:40 PM   #87
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Thanks all.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 08-10-2011, 08:39 PM   #88
esmaytum's Avatar
1963 28' Ambassador
1978 28' Ambassador
Boerne , Texas
re tutorial pics
I would love to see your pictures but for whatever reason they just show up as red "X"s. Do you know why I can not pull them up? Seriously I need help on the whole rivet thing and I REALLY need to see the pictures.
esmaytum is offline   Reply With Quote
Old 08-10-2011, 10:04 PM   #89
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Go to the top of page three. My pictures are still there that photographically show the whole process.
FF
Old 10-20-2012, 06:58 PM   #90
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
A very helpful thread. What a wealth of knowledge exists on this forum.
Thanks to all., bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 11-07-2012, 01:34 PM   #91
1999 25' Safari
Fresno , California
Originally Posted by rluhr View Post
Funny you should bring this up again... my father (an experienced machinist) is making me exactly what shelocta described: a version specifically designed to drill out Airstream rivets.
I won't have it until late spring, but when I get it the plan is to replace a couple of exterior panels with it. I will post here on the results and design of the device at that time. If it works well, I'll investigate having it reproduced by a machine shop.
-- RL
Hi, I'm new to Airstreams and would like to know how your tool worked out - any chance you could give me the info - thanks, Andy
hewettus is offline   Reply With Quote
Axle bearing numbers, 2003 Safari 25 freud Axles 10 11-23-2003 03:34 PM
