Old 10-14-2009, 10:30 AM   #57
Originally Posted by boeingboy View Post
What size olympic rivet was used on exterior of a 61 bambi? What tolls will I need to intall them?
Olympic rivets are an "after market" rivet, that's used when replacing missing exterior rivets, or doing exterior metal work.
There is only one size available, and they have a 5/32" diameter.
DO NOT use any olympics that use washers.
Always use a good sealer under the rivet head, before you insert it into the rivet hole. Vulkem or Par-bond sealers work fine for that purpose.
You can pull Olympic rivets, just like a pop rivet, if you have a decent pop rivet tool.
You then snip the pin off, then grind the pin down with a Dremel tool, or use a small file. This works very well and saves you from buying a "shaver" which costs in excess of $200.00.
Old 10-14-2009, 11:39 AM   #58
1961 16' Bambi
longmont , Colorado
ok, but what size Olympic rivet? Mine have a bigger "hump" in them...I see there are numerous size available in the "olympic" rivets...thanks.
boeingboy is offline   Reply With Quote
Old 10-14-2009, 11:41 AM   #59
1961 16' Bambi
longmont , Colorado
Oh, never mind..just saw post from Inland Rv..thank you very much!
Old 10-14-2009, 11:46 AM   #60
1961 16' Bambi
longmont , Colorado
Does anyone know where I can find a handle replacement for the Bargman 77 lock? Mine is broken off....like others that I see..old posts are from 2005...
Old 12-13-2009, 08:44 AM   #61
Plainfield , New Hampshire
Pictures of rivet procedures missing
Could you please re-post the photos of the procedure for rivets. All that comes up now is a bunch of boxes with red X's in them. Thank you
MikeAir is offline   Reply With Quote
Old 12-13-2009, 09:09 AM   #62
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Here is a good video that shows how to install and shave the rivits.
Richard
Old 12-13-2009, 09:11 AM   #63
Read post # 57.
The proper drill size is a # 21.
A # 20, as some people use, provides a loose fit, which allows the metal to slightly move around the rivet shank.
Old 12-13-2009, 09:40 AM   #64
Ottawa , ON
As well as the great video posted above, the original poster re-posted the images he had put into post #1 into a new post he did, post #47.
Old 12-14-2009, 06:55 AM   #65
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Here is a great rivet removal tool:
Rivet Removal Tool`
It comes with several bits, including #21 and #30. #21 for exterior buck rivets, and #30 for interior skin rivets. You just order the extra bits you need. The tool does not slip off the head, and so you hit the center every time.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 12-21-2009, 07:09 AM   #66
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
I got red x's instead of pictures. Would have liked to checked this out. Any ideal how to go around this problem fellows.
Tom C.
Okiegent is offline   Reply With Quote
Old 12-21-2009, 08:13 AM   #67
Ottawa , ON
Okie: did you look at post #47?
Old 12-22-2009, 03:57 AM   #68
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
Yes I have found it thanks so much for the help.
Tom C.
Old 12-28-2009, 03:48 AM   #69
qc1500's Avatar
rozenburg , netherlands
Thanks guys for the explanation. I am buying an AS and was wondering how to remove rivets and replace them again.
qc1500 is offline   Reply With Quote
Old 04-03-2010, 08:08 AM   #70
Worldturners
tdturn2's Avatar
1976 31' Sovereign
San Antonio , Texas
Don't mean to be a moron, but I am desperate for this information right now and can't seem to find the photos everyone's referring to anywhere
Terry & Natasha Turner
'76, 31' Sovereign International Land Yacht
Remodel Madness
tdturn2 is offline   Reply With Quote
Axle bearing numbers, 2003 Safari 25 freud Axles 10 11-23-2003 03:34 PM
