Old 03-20-2009, 09:59 PM   #43
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by 1963tradewin View Post
Where is the wholesale price?
How many hundred are you planning to buy? THAT is "wholesale". You can buy a hundred at a discount, and sell them to the rest of us at cost.
Old 03-21-2009, 08:24 AM   #44
Dan@LED4RV's Avatar
Denton , North Carolina
If by chance, if you have not seen one of the shavers at work, here is a small video of the installation of an olympic rivet and dressing of the rivet by the shaver.
Click here to see the video.
Also for those one time panel repair people, we are starting rental program for the saver. We are trying to reduce the cost of a repair, on a tool you may only use one time.
Click here to see the shaver.
Please read the terms on the shaver
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 03-21-2009, 09:09 AM   #45
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
So who has the number to the place that makes these shavers? Where is the wholesale price?
We got ours last year at Vintage Trailer Supply. Sometimes they have them "on sale" ~
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 05-30-2009, 04:26 AM   #46
Brighton , Michigan
Ah, so I did. (make a post on this previously, I had forgotten about it)
Posting this followup (to post #23 2005-Oct 6th) ('cause someone asked).
The tool from aircraft-tool.com:
Rivets | Aircraft Tool Supply
works well. Just need to be careful to hold it firmly atop the rivet head and then bring the drill in spinning. So long has you hold the tool in place with a little more force, than you apply to the drill, you're good. Also need to make sure the tool is clean of aluminum shavings after each use. Most of the time the tool ends up clean. Occasionally you need pull some shavings out, but it's no big deal. Hope this helps.
Shawn
shawn_09 is offline   Reply With Quote
Old 06-18-2009, 03:01 PM   #47
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Olympic rivet removal and installation
Originally Posted by PeterH-79MH View Post
I compiled a series of photos for removal and installation of Olympic rivets.
Please note that the rivet in question was a trouble rivet, which didn't want to expand properly. Cutting of a leg of a rivet reduces its strenght and should normally be avoided.
Since the mandrel broke inside, I didn't have to use a sharp nail punch prior to drilling.
Hi Everyone, long time no riveting...Due to many requests, I will try to repost the original pictures.
I still have my 79 and loving it...
ID:	82534   Click image for larger version
ID:	82536   Click image for larger version
ID:	82538   Click image for larger version
ID:	82540   Click image for larger version
ID:	82542   Click image for larger version
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 06-18-2009, 06:19 PM   #48
Hi Peter.
Long time no see.
Old 06-18-2009, 07:56 PM   #49
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Do you use same rivets inside coach. inside ones on my coach don't look that smooth.
Gypsy Jo is offline   Reply With Quote
Old 06-18-2009, 08:02 PM   #50
Olympic rivets are used on the exterior.
Pop rivets are used in the interior.
Depending on what your working on, in the interior, colored pop rivets are available.
Old 06-18-2009, 08:33 PM   #51
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Drilling rivets
Avery Tool Company, they specialize in tools for aircraft, has a tool that goes over the head of rivets and centers them for drilling. Don't remember how much. Avery has a web site, sorry I don't know how to set up a link. A great place for clecos and other items used fixing aluminum be it on the ground or in the air.
Old 06-20-2009, 12:51 PM   #52
shelocta's Avatar
1990 25' Excella
Pflugerville , Texas
Thanks Peter, I can actually follow your instructions......Bill
Give me 40 acres and I'll turn this rig around.
shelocta is offline   Reply With Quote
Old 07-06-2009, 04:13 PM   #53
Centex
1972 31' Sovereign
Lampasas , Texas
Rivet Shaver
I bought one of these $200 rivet shavers a few years ago. I had to return it because the runout of the bit was so bad it would bind up even when turned by hand. The replacement that I received was slightly better but the quality of the product is extremely poor. If there was any competition they would be out of business in a heart beat. I have several similar tools that do not have any runout problems. Perhaps I got the only two bad tools but I don't quite see how that could happen.
dgbingham is offline   Reply With Quote
Old 07-06-2009, 07:50 PM   #54
Please be advised that there are several different manufacturers of rivet shavers.
I don't believe as a whole, they should all be crucified, by your misfortune with one of them.
It would be most helpful to others, if you posted the "brand name" of the shavers you bought.
Thanks.
Andy056
Old 10-14-2009, 09:45 AM   #55
1964 26' Overlander
longmont , Colorado
What size olympic rivet was used on exterior of a 61 bambi? What tolls will I need to intall them?
jimshaner@ms is offline   Reply With Quote
Old 10-14-2009, 09:53 AM   #56
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
look at previous post...
# 47 above. its great for you.
Axle bearing numbers, 2003 Safari 25 freud Axles 10 11-23-2003 03:34 PM
