Old 08-12-2008, 12:07 PM   #29
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Ending the mystery of Olympic Rivets
Took some pix this morning. Below are a couple Olympic's next to a regular pop rivet. The one on the left has the rubber 'O' ring and the one in the center does not. It is recommended to order them without this ring as they deteriorate over time and end up leaking.
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-12-2008, 12:11 PM   #30
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Apply Vulkem around the post before inserting into the hole. Turn it a half of turn to spread the vulkem around to get a good seal. Use a regular rivet gun to install the Olympic. As the stem is pulled out the front of the rivet, the three arms extend to form the bond with the interior of the item(s) being secured. This photo shows partial compression.
Old 08-12-2008, 12:13 PM   #31
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
This shows the Olympic fully compressed. Notice the notch in the remaining post where the rivet is designed to break off above the rivet head. This will get trimmed and shaved later.
Old 08-12-2008, 12:18 PM   #32
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
In the case where you need to apply an Olympic next to a rib or where there is an obstruction on the backside, you can cut off one of the three legs before inserting into the hole and align the removed leg where the obstruction is. This also shows the post has been cut off with a heavy duty wire cutter right down to the rivet head.
Old 08-12-2008, 12:20 PM   #33
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Next up is the rivet shaver. It is a high-priced but indispensable item if you have alot of Olympic's to install. If you only have a few Olympic's to install, either shave them down with the side of a Dremel cut-off wheel and a steady hand or borrow a shaver from a good friend.
Old 08-12-2008, 12:21 PM   #34
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Here you can clearly see the Olympic stem after installation but before being trimmed and shaved.
Old 08-12-2008, 12:24 PM   #35
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Here is the completed installation. The shaved post fills in the hole very nicely and is barely distinguishable from a buck rivet. Once polished, its next impossible to tell the difference.
FF
Old 08-12-2008, 12:46 PM   #36
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
Thanks for the pix Fly!!! This will help when I do the needed work on the outside of GODSPEED.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 08-12-2008, 03:15 PM   #37
Perfect!
Awesome, thanks for the pictures and explanation, Brad. This is just the sort of primer that n00bs like me really need.
So, I take it you use some sort of trimmer to remove the "stem" before you use the shaver to smooth it all the way down, is that correct?
Old 08-12-2008, 06:49 PM   #38
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
No special trimming tool just your typical, run-of-the-mill wire cutters. Nothing fancy, its aluminum afterall, so it cuts really easily.
FF
Old 08-13-2008, 02:31 PM   #39
1964 26' Overlander
Kimberley , ON
Thanks!
This is terrific, Brad...many thanks.
/John
1964 Overlander
jrmott is offline   Reply With Quote
Old 03-20-2009, 06:05 PM   #40
1963tradewin's Avatar
1963 24' Tradewind
, , Minnesota
So who has the number to the place that makes these shavers? Where is the wholesale price?
1963tradewin is offline   Reply With Quote
Old 03-20-2009, 06:39 PM   #41
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Lots of luck on any kind of discount on the Rivet Shaver. I paid about $200 a few years ago.
Olympic Rivet Dresser HS310-5B Rivet dresser for the Airstream Olympic Rivet HS310-5B [HS310-5B] - $249.95 : ODMRV , Out-of-Doors Mart
This is pretty typical.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 03-20-2009, 06:40 PM   #42
We have the shavers.
Axle bearing numbers, 2003 Safari 25 freud Axles 10 11-23-2003 03:34 PM
