Old 05-06-2006, 08:04 AM   #1
1962 16' Bambi
1960 22' Safari
New York , New York
Oh no! I drilled my holes to big. What now?
Well, I'd like to start this post with 3 words. Rivet Removal Tool. From Aircraft Tool Supply. I ordered it this week after really struggling with about 2 thirds of the perimeter exterior rivets on my '62 Bambi which I'm preparing to remove the shell of. This tool makes centering the drill bit and not drilling too deep a snap although it's taken some experimentation to operate correctly as it comes with no tips, tricks, or instructions.
Meanwhile, having now drilled out most of the other third so effectively I now have realized with shock and dismay that I was drilling out the others with too big a drill bit as I was frequently off center and they wouldn't pop off so I just kept getting larger and larger. With the removal tool I was using a #30 bit and just barely poking through when the heads would pop off. Without it my previous holes are slightly larger than a #22 bit.
These are for my exterior skin rivets. Am I totally hosed? Do I now use larger rivets for replacement and if so are the heads not going to match my existing ones? Bummer. FWIW I've only done the very bottom row of rivets around the bottom edge of the trailer. I wish I'd spent more time in the forums BEFORE the drilling. You guys are so full of awesome information. (Like about that rivet removal tool!)
Best!
Steve H.
HamiBambi is offline   Reply With Quote
Old 05-06-2006, 08:18 AM   #2
bill benton's Avatar
Mansfield , Texas
You just have to use larger rivets.
bill benton is offline   Reply With Quote
Old 05-06-2006, 08:26 AM   #3
Images: 59
Steve,
Not a problem. The original rivets were 1/8" modified Brazier Head rivets. If you replace with 5/32" Universal Head rivets they have the same head size.
In fact you may want to drill them out to #21.
Old 05-06-2006, 02:44 PM   #4
1962 16' Bambi
1960 22' Safari
New York , New York
Phew!
Thanks for the comforting advice. And the detailed info about the drill sizes and rivet head sizes. Huge help. Huge relief.
Steve H.
Old 05-06-2006, 03:18 PM   #5
Images: 59
Correction to my previous post. The original rivets are Brazier Head, 1/8" rivet, with a head diameter of 0.312". The Modified Brasier Head 5/32" rivet has a head diameter of 0.312", as does the Universal Head 5/32". The Universal Head rivet stands a little "taller", but I haven't been able to tell the difference.
Old 05-06-2006, 05:10 PM   #6
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
Mark is right. I'm using the universal head 5/32" and you really have to compare the two to notice the difference. I've drilled the originals out with a #30 and now that I'm putting the panels on I'm redrilling the hole with a #21. Seems like there is no end to the number of rivets yet to go.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 05-06-2006, 10:38 PM   #7
1960 24' Tradewind
santa barbara , California
When you buck the rivits in place they will be expanded anyway and tighten in the hole as they are set.There is no need to worry.
Scott
scottanlily is offline   Reply With Quote
Old 05-30-2006, 06:26 PM   #8
Geezer
1991 25' Excella
Sapulpa , Oklahoma
You might want to try the rivets on some metal to see how they work. It is quite simple.
LRPorter is offline   Reply With Quote
Old 05-30-2006, 08:40 PM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Rivets
Hi guys I'm still looking for my first Airstream but I've been an Aircraft sheetmetal mechanic for many, many years. I would'nt venture a guess as to the number of rivets I've shot in the last 35 years. If any one needs any tips all you need to do is ask, I'd be glad to help.
Airstreams in the Movies... InsideOut Our Community 406 12-14-2017 04:23 PM
First Big job.updating toilet from chemi to real rheadhuntress Sinks, Showers & Toilets 2 04-19-2004 06:08 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
