Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 07-09-2005, 12:05 AM   #1
desi arnaz
desi arnaz's Avatar
Profile:
oh my aching ribs
i just got my 2nd set of ribs from airstream,first set was a 6 foot piece with another piece welded to the end to make it 102 inches long.first of all they sent center ribs instead of end ribs.[much thinner metal] the 2nd set seems to have the wrong curve at the top. the ? is..........are there different end ribs between a 2000 excella and 2005/2006 trailers?
there is no real way i can use these and i have one segment out and one new one installed............i will get photos posted in the morning..........thanks tom
desi arnaz is offline   Reply With Quote
Old 07-09-2005, 11:39 AM   #2
desi arnaz
desi arnaz's Avatar
Profile:
picture of new rib
it seems i have the wrong rib again? any ideas?
Old 07-09-2005, 11:49 AM   #3
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
Are you sure the old rib isn't deformed from the crash ? If you took off the old rib, can you push the skin to fit the new rib ? Just curious.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Old 07-09-2005, 12:11 PM   #4
desi arnaz
desi arnaz's Avatar
Profile:
the old rib is gone............what you see is part of the top portion of that rib. everything is back to within 1/4 inch +or-...i have the first of 2 segments installed but cant install the 2nd until i get the ribs to fit.........how do you tell the difference between a wide body coach and a regular? thanks for all your help tom
Old 07-09-2005, 12:35 PM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Tom,
I was under the impression that the radius didn't change between the narrow and the wide bodies...they just added some inches to the overall width and made the top flatter. FWIW the narrow body is 7'-10" wide and IIRC the widebodies were about 8" wider than that.
Aaron
WBCCI #2449 AIR #2495
Old 07-09-2005, 06:23 PM   #6
desi arnaz
desi arnaz's Avatar
Profile:
as you can see the radius is not the way it should be........and i wanted to get this thing put back together this month........i wonder what it could of been from? are they making the new trailers with the cheaper front and rear bows now? mine has the cheaper ones in the middle and the heavy duty ones on the ends...........
Old 07-10-2005, 07:18 AM   #7
lynn
lynn's Avatar
Profile:
It would appear the bow is for a narrow body trailer.
lynn is offline   Reply With Quote
Old 07-10-2005, 12:27 PM   #8
desi arnaz
desi arnaz's Avatar
Profile:
ribs
there has to be something wrong..........the unit is straight as it can be..........the rib is goo until it hits about the 5 foot mark..........maybe this is god's way of telling me to slow down on this restoration?????? i still feel i did very well on this unit though. it will get fixed....maybe not today maybe not tommorrow..but someday............
Airstream Frame mods husky Repairing/Replacing Floor &/or Frame 16 03-06-2005 10:23 AM
Replacement ribs crgintx Ribs, Skins & Rivets 5 01-16-2004 01:27 PM
Mystery window or Haunted Airstream..... Silver Bullet Our Community 12 11-27-2002 06:04 AM
Center folding bed attachment uwe Cabinets, Counter Tops & Furnishings 6 06-30-2002 09:01 PM
test
