Old 02-18-2012, 12:40 AM   #29
1967 17' Caravel
1979 28' Airstream Excella 28
Wheat Ridge , Colorado
We have had good success installing and polishing the new segments from the factory. It isn't easy but it can be done. The new clear coat cannot be removed with chemical strippers. We start with a 300 grit sandpaper on a pneumatic dual-action sander to remove the clear and the mill finish (not brushed) to a smooth surface. We follow up with 600 grit and then 1000. Each set must remove all the scratches from the previous step. When we are finished sanding we go after it with one of our drum polishers and Green Ox compound. We then use a couple of Nu-Vite grades, ending with "S - Final Finish" to protect the shine.
The process takes about 2.5 to 3 times as long as the original metal but it can be done. The two segments marked with red arrows on the 1971 Safari tandem were replaced with the new material.
Brett Hall
Wheat Ridge (Denver) Colorado
http://www.TimelessTravelTrailers.com
Brett - TTT is offline   Reply With Quote
Old 02-18-2012, 03:43 AM   #30
Baltimore , Maryland
... and how much material are you left with Brett? I cannot see removing that much aluminum and having very much skin left. Could you post some photos of the two segments side by side please? From 30 feet it, under florescent light it looks a good match. In the light of day I think the color of the metal will be very different.
Old 02-18-2012, 11:06 AM   #31
1967 17' Caravel
We remove so little metal the difference cannot be measured with a micrometer. We star out with .040 aluminium which has been stretch formed and probably varies from .040 to .037 We remove less than .0005". This is far less material than is taken away when a tree branch scratch has to be sanded out. Keep in mind the sanding process is accomplished with super fine grades of paper.
I will get photos of another unit,in the sunlight, at close proximity, and post them here.
Brett Hall
Old 02-18-2012, 01:18 PM   #32
1981 31' Excella II
New Market , Alabama
Custom multi-segment end caps would be cool. They are also easy to repair since they are flat sheets not die formed.
Perry
Old 02-19-2012, 04:53 AM   #33
Thank's Brett. Always looking to learn something new...
Old 02-19-2012, 07:12 AM   #34
1980 31' Excella II
Ocean View , Delaware
Where is Darkspeed?? I miss him!
Sue
Disneysue925 is offline   Reply With Quote
Hatch hinge material TPdrums Exterior Storage Compartments & Access Doors 10 01-31-2014 07:42 AM
What type of caulking material to use? chrischarles Leaks - Weatherstrips, Gaskets, Caulks & Sealants 29 11-08-2011 10:43 AM
Endcap Compatibility chriscrimmin Ribs, Skins & Rivets 4 10-24-2011 08:43 PM
Removing Dinette Material Rust Upholstery, Blinds, Walls & Interior Finishes 6 10-11-2011 03:22 AM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
