Old 08-09-2009, 09:37 AM   #1
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Question Neophyte's Rivet Questions
Hi,
I am trying to learn about the riveting process by reading various threads.
I am left with these unanswered questions.
How do Olympic rivets differ from regular pop rivets?
Are all Olympic rivets aluminum?
What is rivet shaving and why is it done?
Can I install Olympic rivets with a regular pop rivet tool?
What are some good sources for Olympic rivets?
That's it for now, but I'm sure there will be more.
Ken
Old 08-09-2009, 09:43 AM   #2
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Greetings Ken,
We have our AS on display at the REI in Boulder today 9-2. If you would like to stop by, I would be more than happy to walk you through Rivets 101!!
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 08-09-2009, 09:57 AM   #3
Ag&Au's Avatar
Originally Posted by FLYNCLD View Post
Greetings Ken,
FLYNCLD
That sound great, I noticed your post earlier this AM. Unfortunately, I am about to enter an afternoon of family obligations. I admire your project. It's very ambitious. Maybe I will catch you in another location.
Old 08-09-2009, 10:05 AM   #4
FLYNCLD's Avatar
Bend , Oregon
Well in the meantime:
Bucked rivets are the original rivets used by AS on the outer skin. They must be installed before the inner skin is applied. To repair them, you must remove the skin as well. Olympic Rivets are installed with a pop rivet gun. You then use a "rivet shaver" to smooth out the heads. They are aluminum and can then be polished to look like bucked rivets, and are generally approved for skin repairs.
The rivet shaver is a very expensive tool. Olympic rivets and the shaver can be obtained from Vintage Trailer Supply at Vintage Trailer Supply - Vintage travel trailer parts and supplies!
If you have any other questions let me know!
FLYNCLD
Old 08-09-2009, 10:12 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Welcome from Arvada Co. I have also installed a few rivets so ask away.
Kip
http://www.airforums.com/forums/f416...nte-26902.html
Old 08-09-2009, 10:32 AM   #6
Ag&Au's Avatar
Kip
Hi Kip. As of now, these are my questions:
What is rivet shaving, and why is it done?
Your Avatar looks like you are in the back of a C-130. I spent a few years in Navy P2Vs a few wars ago followed by a career in ATC with the FAA.
I am about to depart on errands, etc for a few hours. I will check here when I get back.
Ken
Old 08-09-2009, 11:29 AM   #7
Aerowood's Avatar
Arvada , Colorado
To answer your questions:
1) Olympic rivets have a solid stem that breaks off on the outside of the rivet shell and needs to be cut flush with the head of the rivet and then shaved with a special tool to match the contour of the heads of the OEM rivets. They can be installed with a good quality pop rivet gun. They are available from the site mentioned above. All Olympic rivets installed in Airstreams should be all aluminum.
2) Pop rivet stems break off inside the shell. These can be obtained in many configurations of materials. Airstreams use them predominantly on the interior and only aluminum stem and shell type should be installed.
I'm an FE/A&P for NCAR. We Operate a C-130 out of Rocky Mountain Metropolitan Airport. Probably talked to you a few times if your were, or are, at Denver Center.
Is this a rivet??? tinbender General Interior Topics 6 11-25-2007 03:29 PM
Any Old Rivet Toby Briggs Ribs, Skins & Rivets 3 07-12-2007 08:43 PM
2 Rivet Questions! TMiller Ribs, Skins & Rivets 2 08-10-2004 05:11 PM
rivet frederic.c01 Forum Admin, News and Member Account Info 2 07-17-2004 11:53 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
