Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 10-14-2003, 12:44 PM   #1
need advice on repair
Can anyone tell me if I can use a rear compound segment from a '68 on a '61 Airstream? I know that the '68 panel is wider but I'm thinking it could be cut down and used as replacement. Any thoughts?
cherring is offline   Reply With Quote
Old 10-14-2003, 11:35 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I don't think it would work. I could be wrong, of course. Try cutting a template out of cardboard that runs across the curve of the '68's skin. Get it to fit very tightly and then compare it to the '61. this would be a good starting point at least.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Step repair took 3 hours--Airstream paid Kistler Our Community 8 11-12-2004 08:09 AM
Seeking Advice.... jtshipp On The Road... 9 05-17-2004 04:42 PM
Floor Repair 1967 Caravel bpaolini Repairing/Replacing Floor &/or Frame 0 08-04-2003 09:43 AM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
