Old 12-10-2017, 08:00 PM   #1
Steamgauge
1966 24' Tradewind
Bonney Lake , Washington
My '66 Tradewind project
As you can see my Tradewind was modified I need a bumper and some aluminum. The back was cut out approximately 6 inches on each side and the top to accommodate a ramp for snow machines, they did not go into the curved portion just the flat. Since I am not looking to do a concourse restoration I am thinking I can replace the frame track and skin out to the existing panels, putting in ribs and stringers based on what I see in the front or put a doubler all the way around match cut the opening to attach a new piece of skin. I noticed there is a double row of rivets in the front and I am wondering if some type of rear attach point was removed. I do not see any signs of material being cut from the frame.
I need ideas on were to get the frame channel, aluminum, rivets, bumper, etc. I have the mechanical skill to do this and the next couple of years to complete the project.
Name:	66 Tradewind.jpg
steamgauge is offline   Reply With Quote
Old 12-10-2017, 08:58 PM   #2
Albuquerque , New Mexico
After working my way through rear-end repairs on our '69, those modifications make me cringe. I'm not sure about '66, but in '69 and later years, there is something called a rear hold-down (those double rows of rivets you mentioned). It is a bent metal plate that attaches the shell to the frame and sandwiches the subfloor between the two. Without that plate, there isn't much holding the shell to the frame. However, if the trailer was gutted and only used to haul around some toys, maybe it wasn't subjected to as many stresses as a fully outfitted RV?
I've documented much of my work on ours on instagram (@lady.clementine). if you search for "rear hold down" (or some form thereof) on these forums, you should get an idea of how it goes together. Again, my knowledge is limited to '69, but you may also be missing some frame members that come down from above and give structure to that whole back section. I wouldn't expect the inner/outer skins to span such a wide area without some framing in there.
Good Luck!
-Matt
Matt0k0 is offline   Reply With Quote
Old 12-11-2017, 08:10 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Greetings from Colorado. I worked on a 66 Trade Wind starting in 2013 and finished last year. I moved on to a 75 Overlander.
It's a pity someone butchered this old Trade Wind. I'm glad you believe you can put it back right again.
Here are some photos of my trailer somewhat disassembled. I had to replace the floor in the bathroom. The frame was ok. It might allow you to identify the frame parts needed back there.
David
Name:	1312 Frame POR 15 Bumper (Small).jpg
ID:	300768   Click image for larger version
Name:	1312 Frame Under Bath Curb (Small).JPG
Name:	1312 Floor New U Channel Center (Small).JPG
Old 12-12-2017, 04:16 PM   #4
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
How about posting a picture of the front?
There are threads hear that show how to do the interior end cap. How about doing something like that?
sgschwend is offline   Reply With Quote
Seeking a 19-21 foot project trailer for Food Truck project debbooooo Airstream Classifieds 0 09-06-2016 02:00 PM
'73 Tradewind Project constructor 1970-79 Tradewind 89 08-14-2014 06:53 AM
1975 Tradewind project - questions! lots of them! keithmac 1970-79 Tradewind 4 03-05-2011 11:10 AM
Got a project here on a '68 Tradewind harestream 1959-69 Tradewind 21 04-05-2007 11:10 PM
