Old 12-28-2006, 03:02 PM   #1
cuyeda's Avatar
Long Beach , California
Mushroom plugs vs. Olympic rivets?
Has anyone used a "mushroom plug" as a rivet replacement? I called Hanson rivets to find an olympic rivet. I was unsure of the specifications, and hoped the Hanson sales persons may have had the same request many times before. Unfortunately, without the exact specifications I did not get a part number to order.
The sales person suggested a "mushroom plug", and stated many trailer restorers use this, and love it. Here is the link to their product page:
Hanson Rivet and Supply Co., Mushroom Plugs
I live in Long Beach, CA, are there any better sources (less expensive) to purchase the olympic rivets? Can anyone tell me the specifications for both exterior and interior replacements? I don't want to use the original style buck rivets if I don't have to.
Cliff
cuyeda is offline   Reply With Quote
Old 12-28-2006, 03:17 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I'd stick with the Olympics for no other reason than they are tried & true and used by the factory when they make their repairs.
Check airstream.com or inlandrv.com for the appropriate ones if you aren't sure what to get.
Shari
Old 12-28-2006, 03:30 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I second staying with the Olympic rivets and make sure you don't get the ones with the washer. The washer deteriorates over time leaving a loose rivet. Interior rivets are nothing more than standard aluminum pop rivets. While the factory may have different color pop rivets, I usually just paint over the heads to blend with the interior color. The Olympic rivets I ordered for the exterior easily fit in a 5/32" hole. If I drill out a rivet, I usually use a 9/64" drill bit to make sure I don't enlarge the existing hole any further.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-28-2006, 03:37 PM   #4
Images: 59
I think they would look awful. They are sized to cover a 3/16" rivet, quite a bit larger than the head of a 1/8" Brazier head solid rivet, or 5/32" Olympic.
The other problem is the method of installation. The stem is inserted into the hollow head of a pop rivet, and pop rivets usually snap off just below the head when you install them in thin metal.
I think they may be for semi trailers, rather than travel trailers.
markdoane is online now   Reply With Quote
Old 12-28-2006, 03:55 PM   #5
cuyeda's Avatar
Thanks for the input. I guess the sales person's suggestion was not as popular as he thought! I will stick with the olympic rivets.
Cliff
Old 12-29-2006, 09:06 PM   #6
1960 24' Tradewind
santa barbara , California
Inland RV usually has the olympics for 20 bucks on sale for 100 quantity.
seems like a good deal for that many .I also use the olympics and the buck rivits too ,both very good.
Scott
scottanlily is offline   Reply With Quote
Old 12-30-2006, 07:40 AM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Use the Olympics where you see the original bucked rivets. You may see pop rivets used in places -- junction of sides to the belly wrap comes to mind. Be sure to use all-aluminum pop rivets and not those with the steel pulls.
5 meter Langford Nahanni
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 07:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 07:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
