Old 03-05-2009, 06:01 AM   #1
Larry in MO's Avatar
1957 22' Flying Cloud
Lone Jack , Missouri
Images: 27
Moving a gutted trailer?
I don't know if this is the correct place for this question but I tried the "search" w/ no results.
The background: my '57 Flying Cloud is nearly gutted inside. I have replaced the axle w/ a torsion model and have new radial tires. I tow w/ a 1/2 ton 2wd truck. I am in the process of removing the inner skin for insulation, wiring, etc.
The question: Can the trailer be moved around (as in towed) with no inner skin? I know it must contribute structurally to have the inner skin intact but will it damage the outer skin if moved about without it? I'm not talking about 500 miles but little trips for various reasons.
Thanks!
Larry
"Turleen", the '57 Flying Cloud
Lone Jack, MO
Pop.528
"You better learn it fast; you better learn it young"-John Fogerty
Larry in MO is offline   Reply With Quote
Old 03-05-2009, 06:34 AM   #2
1958 26' Overlander
Lander , Wyoming
Larry, Obviously the inner skins do add strength to the overall intergrity of the unit. Having said that my 58 was in similar condition; new floor ,axles and wheels with the inner skins out. It was towed to and from storage a couple of times in that condition. The storage was 30 miles away. So, in my expereience there were no adverse effects. Ed
n2batr is offline   Reply With Quote
Old 03-05-2009, 07:16 AM   #3
Thanks!
Yes you can tow the gutted trailer, within reason.
Keep the speed and bumps "DOWN."
Old 03-05-2009, 08:10 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have seen gutted trailers successfully towed for reasonably short distances. One point your original post does not address is, is there a structurally sound floor. The floor also is a factor in the integrity of the monococque design. You might also consider adding some temporary cross bracing depending on how wiggly the unit is, but that is just a guess.
Lumatic is online now   Reply With Quote
flying cloud, inner skin
Brakes working? Getting close to moving trailer... chasrahm Brakes & Brake Controllers 6 02-17-2009 10:55 AM
80% Gutted '62 Globetrotter kidless 1960 - 1964 Globetrotter 14 09-03-2008 02:54 PM
It's gutted, now what? BurnBound General Repair Forum 9 09-16-2004 12:51 PM
Check systems in gutted trailer? malconium General Interior Topics 2 05-18-2004 02:57 PM
