Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 10-09-2003, 05:07 PM   #1
carls017
carls017's Avatar
Profile:
Question Missing Exterior Rivets
On my 1968 overlander I'm missing a few external rivets towards the bottom of the trailer. These appear to be in non-crucial places, but I'd like to replace them for appearance. I have heard that the only way to get to the external rivets in the skin is to remove interior rivets and portions of the wall. The interior of my AS has been 97% beautifully restored by previous owners.
Is there a way to replace these rivets from the outside -- a cosmetic fix? What kind of rivets woud I use?
LaVonne
carls017 is offline   Reply With Quote
Old 10-09-2003, 05:24 PM   #2
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
external rivets are externally applied.
I'm missing a few screws myself but that's a different matter.
AS rivets are either pop rivets (have a hole in the center) or solid Olympic rivets. Pop rivets are available from most hardware stores, Olympic rivets are available at Airstreamdreams, InlandRV, etc. If in doubt as to how to apply them, do a search on "rivets".
Rog
Rog0525 is offline   Reply With Quote
Old 10-09-2003, 05:54 PM   #3
63flyingcloud
Profile:
LaVonne,
You'll want to use Olympic Rivets on the exterior. They can be applied from the outside, without disassembling the interior wall. (They work like a drywall anchor, or molly bolt). When installed, they look just like new--or old, as the case may be.
This is an easy and cheap repair for a dealer, or aircraft mechanic, or metal shop. It takes a couple of special tools, which are very expensive. Unless you're doing a whole bunch of them, it wouldn't make sense to buy the tools yourself--let a professional handle it.
Tom
63flyingcloud is offline   Reply With Quote
Old 10-09-2003, 07:05 PM   #4
carls017
carls017's Avatar
Profile:
Smile The Rivet Question
Rog and Tom, thank you. I guess the few missing rivits that I have are Olympic rivits. I think I'll not worry about it as this point.
Funny how compusive one gets when one has her first vintage AS.
LaVonne
Old 10-12-2003, 02:17 PM   #5
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Actually, Olympic rivets can be installed without the fancy equipment that Tom mentioned...the bucked rivets are the ones that require pros, removing inner skins and special equipment.
We have ordered and installed Olympic rivets ourselves, no problem with a regular rivet gun. If you wnat to finish them off like a pro you can "shave" them either by hand or with a Dremel tool. It you have a bunch to do, you may want to invest in a rivet-shaver which runs about $180.
Good luck!
Shari
Old 10-13-2003, 08:55 AM   #6
Perry
pezz
Perry's Avatar
Profile:  1982 34' Limited
mire poix , midi pyrenees
rivets
HI ALL
what's the tool like and whats drywall and molly bolt?
dont know any of that over here?and thats only the rivets!!!
thanks perry
PERRY
First European Airstream park http://www.airstreameurope.com
Perry is offline   Reply With Quote
Missing cabinet door dmadam Cabinets, Counter Tops & Furnishings 7 03-19-2004 11:46 AM
Aluminum underbelly missing Joe C 2003 International 10 11-10-2002 09:41 PM
66 Safari - step and window guard parts? Gordon 1966 - 1968 Safari 1 04-20-2002 11:16 AM
