Old 02-14-2013, 03:09 PM   #29
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The rub rail insert is supposed to cover the rivets, not have a rivet through it. FYI the rivets under the rub rail are typically pop rivets.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 02-14-2013, 07:04 PM   #30
2009 34' Panamerica
weyburn , Saskatchewan
This what put hole in strip on bottom of trailer.
Pedecanada is offline   Reply With Quote
Old 02-14-2013, 07:12 PM   #31
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
So the rub rail trim on the protector damaged the rub rail on the trailer....if you're the original owner take it to dealer. That probably will have done only surface damage to the rub rail insert but not all the way through. I wouldn't bother because its never seen anyway
Protohyp is offline   Reply With Quote
Old 02-14-2013, 09:23 PM   #32
1988 32' Excella
Robbinsville , New Jersey
That looks like regular pop-rivets where someone used ones that were twice as long as they should have been, my guess is a PO. You should just use a dremel and grind them down some, not to much or they wont hold anymore, leave a 1/16"-1/8" sticking out.
