Old 06-22-2011, 10:14 PM   #1
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Is there any reason I couldn't use sheet aluminum clad to replace a lower radius panel? Or, does the actual panel have some kind of pressed convex shape? Just wondering because I have to replace two lower curves and the rear flat panel and have located sheet material for about $200 total.
Phrunes is offline   Reply With Quote
Old 06-22-2011, 11:39 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
As far as I can tell, only the upper end caps have compound curves.... a quick way to figure it out: take a sheet of paper - if the paper will lay smoothly against the entire panel, the panel is either flat or a conic section - bent in only a single direction. If the paper won't lay flat, it was formed on a wheel or press rather than just bent into position.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-22-2011, 11:45 PM   #3
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Thanks Bart!
Old 06-23-2011, 02:58 AM   #4
Baltimore , Maryland
sorry, but all those 70's and on are formed panels. Get ready to fork over the cash on those. 1978, you will need to go to Inland Rv for that...
Old 06-23-2011, 06:46 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I replaced mine with flat sheet, BUT there was some forming involved. See my thread below for details
http://www.airforums.com/forums/f416...nte-26902.html
Old 06-23-2011, 09:50 AM   #6
toddster's Avatar
1967 20' Globetrotter
Campbell , California
I've got the upper panel shown in the pic plus the streetside-front/curbside-rear lower wrap around panel (both NOS Airstream). Let me know if either of these are what you need and maybe we can work out a deal.
Name:	Airstream Front.jpg
toddster is offline   Reply With Quote
Shipping skins or panels....??? mrsfixit Ribs, Skins & Rivets 5 04-15-2011 11:31 AM
Repair to Interior Door Panels of Dometic M 70b 69 AirDream Refrigerators 13 04-01-2011 07:15 AM
Hail Damage to Roof Panels dgilchrist44 Roof 0 03-21-2011 05:16 PM
Refer panels lahrfarm Refrigerators 6 02-28-2011 09:47 PM
any suggestions on making bread or rice in an Airstream? aname4me Stella's Kitchen 57 01-31-2011 10:08 AM
