Old 06-15-2015, 10:56 PM   #1
Detroit , Michigan
Major dent advice - 1984 31' Excella
Hi everyone, I'm new here and this is my first post. Quick question about an airstream I'm in the process of acquiring from a good friend (1984 31' Excella). It has some pretty major dents as you can see in the pictures.
My question is... what options do I have to deal with this dent? Can I make it look any better with a low-cost fix? What will it take to have it repaired or replaced? I'm on a very limited budget so the cost is a big concern. Please let me know what you think my options are here and what it might cost.
Thank you in advance!
ID:	240754   Click image for larger version
ID:	240756   Click image for larger version
Masterlock is offline   Reply With Quote
Old 06-15-2015, 11:04 PM   #2
1974 Argosy 20
Kooskia , Idaho
Nothing will make that look or work better other than a complete replacement of all of the mashed and bashed panels. Those are not dents, they are completely destroyed panels, and the interior must be damaged also.
$8,000 to $10,000 will fix it, but it is not worth it.
Old 06-15-2015, 11:15 PM   #3
Detroit , Michigan
Thanks for the quick feedback! Do you think this trailer is worth getting and if so how much would be a fair market value? Everything is original and still works but it has this exterior damage.
Old 06-15-2015, 11:15 PM   #4
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Airstream + "I can fix it cheap" = terrible idea.
Get some quotes for the repair, looks like multiple panels need to be replaced, never mind whatever water damage may lurk inside...
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 06-15-2015, 11:16 PM   #5
1974 Argosy 20
Kooskia , Idaho
On further looking at the photos, I see the front is also trashed. My cost guess is then too low.
Old 06-15-2015, 11:17 PM   #6
1974 Argosy 20
Kooskia , Idaho
No, the trailer is not worth getting.
Old 06-16-2015, 12:22 AM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I know someone in Texas who has replaced similar panels. It was not cheap. You need 'covered' area to perform repair... you need the skills for drill, Cleco's, buck riveting, etc.
Short story..
He ripped out the interior walls to gain access to the area.
When the new panel arrived, He then removed the damaged panel(s), then installed 'new' by drilling and riveting through the same holes which were on the original ribs and where they match other panels. EXTREME Care is needed as sloppy holes in metal structure is not good.
If you can get a great price... If , if, if, etc... and you have the space/time, and are willing to be patient, you may 'fix' this for less than $3000.
My bet, tho, is, not knowing the whole story, that there is water penetration which has damaged the floor... that's a whole other set of issues.
How 'cheap' will you be 'getting' this damaged AS for?
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-16-2015, 04:28 AM   #8
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Two years ago I backed into something that left a large crater dent in my left rear middle corner panel like where your damage is. I was able to use dent pullers to get out a lot of the crushed in damage making it look like crinkled foil but aluminum stretches unlike steel so I took my Airstream to highly recommended Airstream metalwork dealer (Airstream recommended them as a dealership with such knowledge). The corner panels are about $1800 each. I am not sure how they fix the other body issues.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-16-2015, 04:48 AM   #9
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
rear and side alone is 15k plus, if there is no internal structural damage.
Free may be too expensive...
Enjoy as is or run
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 06-16-2015, 05:19 AM   #10
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
If you took a few more detailed pictures, and emailed them to the service manager at the Airstream facility at Jackson Center, I think they would give you a ball park price, at least they did for me a couple years ago. They would need to see what specific panels need replaced, and how much internal damage was done. If you remove the interior where there is skin damage, the service folks could evaluate any rib damage, and...it would save you money, as they would not need to remove the interior, if they did the work for you.
Bauxter is offline   Reply With Quote
Old 06-16-2015, 05:41 AM   #11
1981 31' Excella II
New Market , Alabama
Might be better off finding a donor trailer to get parts off of. I know of one in this area but I am not sure if the guys would want to sell just those parts. I would like to get some windows off the same trailer. As far as buying new panels and fixing it that way would cost more than it is worth. That trailer is worth about $15k if it were near mint condition. You will put $10k into the structural repairs and another $10k at least to fix the rest up.
Perry
Old 06-16-2015, 05:46 AM   #12
Kevin245's Avatar
The cost to repair with replacement panels will exceed the value of the trailer. This is a "Write Off" trailer IMO. What is the status of the title?
Eleanor Roosevelt
Old 06-16-2015, 09:11 AM   #13
Detroit , Michigan
Title is clean. I'm buying the trailer for $1,500. It does have the major damage plus a couple more smaller dents but honestly it doesn't bother me too much and I'd like to just make it look as decent as possible for the time being so I can use the trailer. Maybe look for a prettier solution for the future. Thanks for all the feedback so far! If anyone has any ideas about inexpensive "band-aid" solutions that would look better than it looks now please let me know. Maybe someday I'll have more of a budget to restore it better.
Old 06-16-2015, 09:57 AM   #14
Kevin245's Avatar
This looks to be a mid-bath model which means accessing the inside of the skins is far easier than a rear bath model where everything needs to come out to gain access. You'll be surprised at how much better the major dent in the rear will look with some body massaging from the inside. It will still be wrinkled but the shape will be much improved.
It won't be a beauty queen but you can make it functional if you're willing to overlook cosmetics and there is no structural damage.
Best of luck,
Kevin
Eleanor Roosevelt
Major revision to 1981 Excella Roddyy Classic Motorhomes 2 07-10-2014 08:34 PM
Advice on fixing this dent navyeod Ribs, Skins & Rivets 23 04-17-2009 03:24 PM
Help! I need advice on fixing a big dent. Deborah Penn Member Introductions 18 06-08-2008 07:42 AM
Dent advice... TennisMan Ribs, Skins & Rivets 15 09-08-2007 09:28 AM
thanks for the advice on the dent wayne.yl Ribs, Skins & Rivets 8 11-07-2003 05:23 AM
