Old 07-31-2012, 09:38 AM   #1
mukluk25's Avatar
1967 26' Overlander
Carbondale , Colorado
Main door catch rivet.
Hi, I am new to rivets and wrenching on Airstreams. I was going to cut my teeth on replacing the main door catch which has rusted out. Can someone give me an idea of which rivet and size to use for this based on the picture? Also, maybe what drill bit size to use as well? Thanks
Name:	door catch rivet.jpg
mukluk25 is offline   Reply With Quote
Old 08-02-2012, 09:44 AM   #2
mukluk25's Avatar
1967 26' Overlander
Nobody?
OK, so if no one knows could someone suggest a kit of rivets I should get for my '67 Overlander? Maybe someone sells a package of all the sizes you might need? Thanks
Old 08-02-2012, 09:48 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Should be a standard 1/8 inch pop rivet with a short grip range. A 1/8 drill bit will drill make short work of removing the old rivets. Put a little dab of sealant on the new rivets before you insert them and set them with the rivet gun.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-02-2012, 10:14 AM   #4
1981 31' Excella II
New Market , Alabama
Ditto on the last post.
Perry
Old 08-02-2012, 10:53 AM   #5
mukluk25's Avatar
1967 26' Overlander
Cool thanks! What type of sealant do you suggest? Is there a certain brand of rivet I should use? Thanks
Old 08-02-2012, 10:59 AM   #6
sandlapper's Avatar
1993 34' Excella
York , South Carolina
A squirt of Parbond in the hole/on the rivet. And an aluminum rivet.
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 08-02-2012, 11:24 AM   #7
68 TWind's Avatar
1968 24' Tradewind
Parbond, Vulkem, even gutter seal will all work but not silicone. You don't need a lot just a little dab will do you.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-02-2012, 11:35 AM   #8
mukluk25's Avatar
1967 26' Overlander
Great info. thanks a lot!
Old 08-02-2012, 12:08 PM   #9
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
I use aluminum compatible silicone... works good for me...
Friday is offline   Reply With Quote
Old 05-06-2017, 12:00 PM   #10
angieair's Avatar
1969 21' Globetrotter
Colorado Springs , Colorado
I need to do this as well! Do you remember, did you also replace the little catch piece that is on the actual door? If you did, what type of rivet did you use? Wondering what to do since on my 69, it's riveted in the door edge, so the rivets need to be short and flat on the inside.
ID:	284876   Click image for larger version
angieair is offline   Reply With Quote
