Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 04-27-2008, 12:11 AM   #1
Petethefeet's Avatar
1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan , New Zealand
Images: 14
Load bearing or not load bearing?
This may sound like a dumb question considering it appears that there are plastic wheel well covers in use, but are the wheel well covers load-bearing at all? A detail on the pic below ( a bit far away, I know ), is the ribs that run down to land on the initial wheel well cover, originally with a tab running off the inside edge of the rib to be riveted onto the top face of the cover. Do these just locate the outside skin laterally ? I have replaced the original tabs as they were fatigued, same guage, but not riveted them off yet. Just curious.
Petethefeet is offline   Reply With Quote
Old 04-27-2008, 12:32 AM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
No, those wouldn't be load bearing. Although, none of the ribs are really "load-bearing" in the traditional sense of the term. Airstreams are monoque construction, so the whole thing is supported by being tied together...not just on the ribs (columns) as in stick construction.
Some "ribs" or vertical channels are there as backers or vertical supports for interior cabinets.
Just curious, which trailer is this in? The layout may help me to understand what the pseudo-ribs are there for.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 04-27-2008, 01:57 AM   #3
1964 30' Sovereign
1957 26' Overlander
Images: 14
Interesting. It is in a 1964 Sovereign, the photo is looking rearward.
Pete
Old 04-27-2008, 07:36 AM   #4
Retired.
. , At Large
The "load" of that rib is spread through the other braces and ribs.
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
How not to load a vehicle dpandorf Tow Vehicles 11 06-28-2007 07:45 AM
Load range D or E? Bing-Bing Tires 5 05-30-2007 01:26 PM
Snow Load Navigator Winterizing, Storage, Carports & Covers 54 02-03-2007 02:13 PM
Which Load Range sander17 Tires 27 05-04-2005 06:53 AM
