Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-07-2005, 10:55 AM   #1
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Little Rivets....
anyone know the proper name for the small rivets that are used to attach the window frames to their hinges on the 70's trailers? and what kind of tools are needed to attach them? there is one loose, and a couple missing from my front window. also, the referidgerator access door, which has the same type hindge as the windows, was re-riveted by someone at some point, and they used steel rivets. guess what? they rust. duh.
anyway...these aren't pop-rivets. and they aren't as big as the bucked rivets used on the shell, but they do have solid, rounded heads. I'd like to replace the missing ones, and re-do the steel ones. but I need to know what kind of rivets to buy, and what tools are needed/how to use them.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-07-2005, 11:29 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Chuck.
Regardless of size, those rivets are called "buck" rivets.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-07-2005, 11:39 AM   #3
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Chuck
Durring my battle of putting the window back in after removing it to replace the gasket, I lost.
All of the original rivets popped because of the improper way I was trying to get the window back in.
I ended up just using aluminum pop rivets. For better or worse it has held up fine.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 06-07-2005, 12:39 PM   #4
Chuck
Chuck's Avatar
Images: 99
I think the same thing happened to me. on at least one rivet, anyway. others were already missing. there's a trick to getting those windows back into the hinges.
anyway, I seem to remember seeing someone demonstrate riveting w/ some sort of anvil type thing on one side, and a "set" or punch on the other, and hammering the rivet with a regular hand-held hammer. or a tool that incorporated both of these functions. am I barking up the wrong tree, here? not a pneumatic rivet gun..."hand tools".
Air:291
Wbcci: 3752
'73 Safari 23'
Old 06-07-2005, 01:01 PM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Chuck,
You can hand buck the rivets but, with the current prices of air tools at Harbor Freight it almost isn't worth it....You need a hammer and a bucking bar (anvil) check for Aircraft Spruce catalogs...IIRC they have them in there.
Aaron
WBCCI #2449 AIR #2495
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 07:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 07:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
