Old 08-12-2010, 09:32 AM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Let's see your patches!
I'm going to need to patch a few areas on my skin and am interested in patching methods and shapes. I've seen some unique and interesting shapes. Lets see yours.
SilverHoot is offline   Reply With Quote
Old 08-12-2010, 10:30 AM   #2
asbury park , New Jersey
heres our finished patch after polishing (we went with an on demand water heater so closed up the old HW heater vent)
heres a close up. you can see that with our first few olympics, we used a dremmel to sand it down after clipping it. after the 1st one or 2, i surrounded each olympic rivet with blue painters tape so i didnt scratch up the aluminum with the sander. learn from our mistakes! i didn't buy the $200 olympic rivet finishing tool, i didnt think it was necessary. almost all of the little scratches from sanding buffed out w/ polishing.
NJtoNC is offline   Reply With Quote
Old 08-12-2010, 04:32 PM   #3
SilverHoot's Avatar
1967 24' Tradewind
NJtoNC,
Looks good, was wondering how much to overlap. We hope to be CAtoSC someday soon. Hope some more post their pics, my patches are not going to be anywhere near that large and because I have the interior skins removed, be going with buck rivets. I have a patch to do at the front corner next to the window where the TV antenna gizmo was attached, old AC holes in roof, furnace exhaust holes and I think where the front window protector brackets attached.
Old 08-12-2010, 06:50 PM   #4
Baltimore , Maryland
I love making patches. I do it as a creative stress reliever. When someone contacts me for a patch, I tell them the cost of the materials and let them decide what it is worth. Here are just a few I have done...
ID:	108690Click image for larger version
ID:	108689Click image for larger version
Old 08-12-2010, 07:04 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Very Cool, Frank!
TB & Greg and Abbey Schnauzer
#3954
Old 08-12-2010, 07:07 PM   #6
SilverKing's Avatar
2016 27' Eddie Bauer
Saint Petersburg , Florida
Wow! That really is cool. Go Frank!!
SilverKing is offline   Reply With Quote
Old 08-12-2010, 07:26 PM   #7
SilverHoot's Avatar
1967 24' Tradewind
You go Frank! Now THOSE are what I'm talking about! Love the star.
Old 08-12-2010, 07:37 PM   #8
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I patched both antenna's on my 65 Safari. You can see the patch on the upper right side over the radio antenna hole and just to the left of the Air sticker covering the tv antenna.....TK
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 08-12-2010, 09:35 PM   #9
SilverHoot's Avatar
1967 24' Tradewind
Good job TK your trailer has always been one of my favorites. Never noticed the patches before.
Old 02-05-2013, 02:00 PM   #10
My Motorhome is from '84, so what material and thickness should I get to do some patches?
I have seen Rems of 3003, 5052, and 6061 in various thicknesses at my local metal suppy place.
I already picked up some 5052 in .090" and .050"...
Old 02-05-2013, 02:26 PM   #11
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Here's our radio antenna delete....
Name:	IMG_2398 (Medium).JPG
goshawks00 is offline   Reply With Quote
Old 02-05-2013, 02:29 PM   #12
1981 31' Excella II
New Market , Alabama
6061-T6 is pretty good stuff. 5052 is soft and made for die forming and easy bending so I would not go less than .040 thick on that. .032 should be fine in 6061-T6 or 2024-T3 Alclad. Any alloy that is Alclad will polish better and resist corrosion. 5052 will polish well since it is a low temper alloy. Aircraft Spruce should have what you need. A city of any size should have a sheet metal distributor or welding supply shop that can get what you need. If you want small sheets, you can get those from mcmaster.com.
Perry
Old 02-17-2013, 05:48 AM   #13
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Pretty cool normally I resist the urge to get a tattoo but the aluminum ones look good and serve the purpose.
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 02-19-2013, 09:18 AM   #14
supergg's Avatar
1969 31' Sovereign
middleboro , Massachusetts
Frankenpatch
The PO must have been an artist. He blended this patch right in. Can you make it out? I see it as abstract art that means different things to different people. To me this patch says change me. I have all the shaped segments for the entire end. All I need is to get to the point that I can install them. For now the Frankenpatch end of the trailer points away from the house and out of sight.
supergg is offline   Reply With Quote
Old 02-19-2013, 09:59 AM   #15
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Wow That is some interesting patchwork. Are the patches held on with sheetmetal screws?
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-19-2013, 10:25 AM   #16
supergg's Avatar
1969 31' Sovereign
Yep. Not even stainless. The rust stands out a bit. To be fair, I must say it does not let water in.
Old 02-21-2013, 10:53 PM   #17
K&GLittle
1966 30' Sovereign
2015 27' FB International
Paola , Kansas
"Frankenpatch"...genius! That's awesome!!
klittle is offline   Reply With Quote
Old 03-26-2013, 08:45 AM   #18
SilverHoot's Avatar
1967 24' Tradewind
Attachment 179325
BARELY! ............through my tears.
Old 10-18-2014, 05:55 PM   #19
Anchorage , Alaska
Finished riveting after dark, and it looks like I messed up one of these rivets, but don't feel like redoing. (Didn't the Navaho blanket weavers put an error in, so as not to offend the gods? If so the gods will be bonkers over this project !!)
Aktundra is offline   Reply With Quote
Old 10-18-2014, 08:17 PM   #20
StreamlineAK's Avatar
2014 25' FB Flying Cloud
Anchorage , Alaska
Images: 12
Originally Posted by aktundra View Post
finished riveting after dark, and it looks like i messed up one of these rivets, but don't feel like redoing. (didn't the navaho blanket weavers put an error in, so as not to offend the gods? If so the gods will be bonkers over this project !!)
love it!
StreamlineAK is offline   Reply With Quote
clear coat in patches safari 28 Ribs, Skins & Rivets 4 05-15-2008 10:29 PM
patches mizzen Our Community 2 07-18-2004 10:59 AM
