Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 03-14-2017, 07:44 PM   #41
Love it!
Old 12-22-2017, 03:01 PM   #42
Margritc's Avatar
1964 17' Bambi II
Lakehead , California
Love all the artistic patchwork.
Margritc is offline   Reply With Quote
Old 12-22-2017, 10:44 PM   #43
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Detroit , Michigan
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 12-23-2017, 02:48 PM   #44
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Got to love a painted Argosy! Click image for larger version
ID:	301333Click image for larger version
1973Argosy is offline   Reply With Quote
Old 12-25-2017, 08:48 PM   #45
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Originally Posted by Atomic_13 View Post
Love your patch!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 04-25-2018, 10:00 AM   #46
AeroHead Aviation
tjmartini's Avatar
2018 30' Classic
Simpsonville , South Carolina
Power Plug Patch
I incurred some damage at my shore power plug and intend to fabricate a patch to cover and strengthen it. Has anyone done this and can comment? I plan to use 2024-T3 0.032". It will basically look like a picture frame, unless I decide to get creative.
1. Am I using the correct aluminum?
2. What type rivets are recommended, Brazier AN455, Mod Brazier AN456, Universal AN470?
3. What size rivets, dia, length, head?
I'll be using a ATS 3XPro rivet gun
Thomas Martini
GE Mechanical Drivetrain Test Engineer
Skydive Carolina Pilot
2017 GMC 2500HD, 2018 Airstream Classic 30, Propride 3P
South Carolina WBCCI Region #3, Unit #22, #18675
tjmartini is offline   Reply With Quote
Old 04-25-2018, 11:15 AM   #47
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
The aluminum is fine. Vts has the rivets and size instructions.
Matt
rugjenkins is offline   Reply With Quote
Old 06-12-2018, 07:39 AM   #48
redondo beach , California
I worked on a silver streak clipper with corrosion. hey were from TEXAS so we put the shape of Texas on
ID:	313811   Click image for larger version
PLVMB is offline   Reply With Quote
Old 07-11-2018, 09:09 AM   #49
@steadystreamincashios
Zcashio's Avatar
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs , Arkansas
Just curious.. how exactly are you streamers cutting your patches? Just aircraft tin snips? I would consider myself handy, but looking at all your artwork, I think I need practice!! Nice work to all of you!
Thanks for any advice.
Zcashio is offline   Reply With Quote
Old 07-14-2018, 07:52 AM   #50
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I also am very interested in tools and techniques for cutting irregular shapes for patches especially complicated shapes.
I can only find partial sheets of 5052 aluminum locally. Is it suitable?
Old 07-14-2018, 09:35 AM   #51
rugjenkins's Avatar
1975 Argosy 28
Yes 5052 will work, I used 3003. No issues
Matt
Old 07-16-2018, 07:31 PM   #52
Lumatic's Avatar
1993 34' Excella
Images: 16
Roto Zip Spiral Saw
Has anybody used a Root Zip or other spiral saw to cut out shapes?
Old 08-17-2018, 01:34 PM   #53
Lumatic's Avatar
1993 34' Excella
Images: 16
Big Patch for big dent
I have now changed my Airstream's name to the "Silver Lizard".
Since the patch covers upper and lower segments, both are compound curves, and I do not have access to an english wheel this is a 2 piece patch. Without an english wheel this is about the size limit from side to side without too much distortion to the sheet aluminum. Another option would be more pieces for the patch.
ID:	320128   Click image for larger version
Old 08-17-2018, 02:17 PM   #54
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Brilliant!
Old 08-17-2018, 04:33 PM   #55
Superb!
I have questions...
How did u match the double curve of the corner on the underlying patch?
English wheel?
I have these to replace/repair/cover....
Name:	Airstream ## 008.jpg
Old 08-17-2018, 05:58 PM   #56
Lumatic's Avatar
1993 34' Excella
Images: 16
Superb!
I have questions...
English wheel?
I don't have an English wheel. There is a sheet metal shrinking tool out there. I think Harbor Freight has them. Did not use that either. Either would have been nice. With a tag board pattern I got an idea how the metal would bend. The width of the 2 part patch is about as wide as you can get without excessive buckling at the side edges. I had some minor bucking that I was able to mostly draw in with more rivets. Clecos help a lot to see how it is going to work and start to draw in the patch edges. Also used soft aluminum, but I don't know the grade.
Old 08-17-2018, 07:57 PM   #57
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
I just paid a local metal fabrication concern to use their precision cutting tools for my patch. They have templates for all 50 states.
Name:	180505 holes.JPG
ID:	320153   Click image for larger version
Name:	180505 clecos.JPG
Name:	180505 installed afar.JPG
ID:	320155   Click image for larger version
Name:	180505 installed close.JPG
Slats is offline   Reply With Quote
Old 09-18-2018, 01:08 PM   #58
1973 Argosy 20
1968 24' Tradewind
Kingsville , Ontario
My patch in our 73 Argosy
Found a hole right beside the door after I stripped the Argosy - tried to make it look like it was a name plate or badge.
roostream is offline   Reply With Quote
Old 09-27-2018, 08:46 AM   #59
TEXAS patch cut by hand
ID:	323825   Click image for larger version
Old 01-31-2019, 04:40 PM   #60
Lumatic's Avatar
1993 34' Excella
Images: 16
Coyote patch
(the patch on the right is shown in an earlier post)
clear coat in patches safari 28 Ribs, Skins & Rivets 4 05-15-2008 09:29 PM
patches mizzen Our Community 2 07-18-2004 09:59 AM
