Old 06-05-2010, 08:32 AM   #1
1994 34' Limited
colebrook , Connecticut
leaking rivets
Hum,
I'm trying to figure out how to fix 3 olympic rivets in my door frame without drilling them out . I'm not sure their all their cracked up to be.
malett is offline   Reply With Quote
Old 06-05-2010, 09:49 AM   #2
Originally Posted by malett View Post
Hum,
Olympic rivets are fine.
If they leak, blame the installion.
You can work some Vulkem sealer around and under the edges and heads of the olympics.
Then wipe off the surplus.
Olympics, when installed correctly, should have a small bead of Vulkem sealer placed on the shank of the rivet, before it's inserted into the sheet metal.
Old 06-05-2010, 11:22 AM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
Alcoa Gutter and Seam sealer can be used to minimize immediate problems; for a long term fix, drilling 'em out and installing per Andy's suggestion is wise.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Leaking Rivets excella80 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 04-09-2010 08:14 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
