Old 04-27-2008, 05:57 PM   #1
Baltimore , Maryland
it sticks up
I have this rivet...Click image for larger version
It sticks up and that worries me. The gap under the head is about two business cards thick. The rivet is firm and does not wiggle at all. This rivet joins two sheets and goes into a rib. I know I can put vulkum under it, but it sticks up... could I take my riveter and work it down? Maybe a 4x head instead of 3x to pean it over more? Should I just leave it alone? I want to try and drive it down, but do not want to make it worse. If it does not work, it could be drilled out and replaced with an Olympic. What do some of you more seasoned restorers think I should do?
Old 04-27-2008, 06:24 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There looks like a gap under the rivet. I'd drill it out (no putty knives), put some Vulkem in the seam and in the rivet hole, and re-rivet it.
Old 04-27-2008, 06:34 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
It has lost it grip. It needs replacing. Do not drive it back in it will bend the rib.
Michelle TAC MT-0
Sarah, Snowball
Old 04-27-2008, 07:01 PM   #4
1973 25' Tradewind
Romulus , New York
drill it out
Will you be happy with a marginal repair? I thought not.
jayray5 is offline   Reply With Quote
Old 04-28-2008, 02:45 AM   #5
I will not be happy with a marginal repair, you are right. I am in way too deep to do anything marginal. However, I think the best solution is the one I will take.... The possibility of removing the entire interior again, removing all the interior skins to re rivet one rivet is just not realist. If I were to do that,well, I hope someone would commit me. I think I have heard the "best" solution and that is to drill it out and replace it with an Olympic. A five minute repair or a two week long repair, those are my choices. This has kind of become a no brainer.
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
