Old 04-06-2009, 04:06 PM   #1
bocotim's Avatar
2008 16' International CCD
Boulder , Colorado
Images: 75
Is this dent hard/expensive to have repaired?
This is a photo that was sent to me by the owner of a trailer I am interested in. It has a dent in the rear curbside corner. I haven't seen the trailer in person yet, but I am told the skin is not pierced nor did the dent cause any problems on the inside of the trailer.
I am just wondering if this type of problem is easily fixed and expensive to repair? Would it likely require the removal/replacement of a panel or do you think it could be fixed using one of those do-it-yourself dent repair kits that are used to take out hail dents on automobiles?
Tim
bocotim is offline   Reply With Quote
Old 04-06-2009, 04:33 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
That is a panel replacement dent. If you were willing to remove the interior you could make it marginally better buy working it from the inside, but the best bet is replacement. Others here on the forum would have a better idea on the cost then me.
Aerowood is online now   Reply With Quote
Old 04-06-2009, 04:34 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Depends on your idea of fixed. It can be pulled out with hot wax and sticks at very little cost, but will leave evidence of the dent . If the panel is replaced that is big bucks and most likely will bring additional problems down the road such as leaking.
2004 Excursion 4x4
Old 04-06-2009, 04:36 PM   #4
Tim
Replacement cost, depending on the labor rate, is ball park, $1100.00 to $1200.00.
Contact your insurance company.
The dent is creased. Therefore the panel will always look poor.
Old 04-06-2009, 04:37 PM   #5
Levon's Avatar
1985 27' Sovereign
1981 22' Excella II
Colbert , Georgia
Images: 168
From the photo, it looks like there is a crease along with the dent. If so, the crease has stretched the metal and will always show. If you want to fix like it was not there, you have to replace the panel...expensive! Depending on the year of the trailer, different prices, and labor is also expensive. The price of the trailer should reflect the dent. (approx. $1,500/2000). Hope this helps.
Levon
Levon is offline   Reply With Quote
Old 04-06-2009, 04:41 PM   #6
1973 25' Tradewind
waynesboro , Virginia
In my opinion, you can make a significant improvement by having the dent pulled,
however, with the crease shown, it may never be perfect, probably can have
dent wizard or dent doctor do the job for around $150 with the knowledge that
while much better looking the crease will remain...
waltero is offline   Reply With Quote
Old 04-06-2009, 04:44 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Tim. It's generally been said that type of dent produces stretching of the metal. Evidence will still be visible even if it is popped out. A number of threads are out there on this subject. They'll be among the results of this search.
I haven't had to deal with this one yet. Knock on aluminum...
5 meter Langford Nahanni
Old 04-06-2009, 04:50 PM   #8
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
You should consider this as a ..."take a trip to the Mothership".. in Ohio..cost to replace this panel, correctly.. 1500$ TOPS..I figure less..(1200$)
The food and, the fun....is worth the trip..
Enjoy...
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-07-2009, 09:00 AM   #9
bocotim's Avatar
Boulder , Colorado
Images: 75
Thanks folks - your responses answer my questions. It's not what I wanted to hear, but it is what I needed to know.
Tim
Old 04-07-2009, 09:05 AM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If you can get this Airstream for the right price, It can still be a great deal. If the unit is otherwise perfect, you just might get a great Airstream for a great price.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 04-07-2009, 09:28 AM   #11
2008 25' Classic
Sometimes it's Heaven , USA
I had a very simular dent on my Safari. I was able with use of a suction cup dent puller get it to pop out by pulling it VERY CAREFULLY.. Iwas lucky I know, and it really only showed the repair when certain angles of sun hit it and you were looking for it.. It would be worth a try... The bigger dent was my ego for backing into the bush in the first place...
COUNTRYSONG is offline   Reply With Quote
Old 04-07-2009, 10:12 AM   #12
HowieE's Avatar
Images: 12
Don't let that small dent stand in your way. You can at least blame it on the previous owner.
It will not effect the use of the rig.
2004 Excursion 4x4
Old 04-07-2009, 10:23 AM   #13
1963 24' Tradewind
San Diego , California
I agree!!!
Sixty3TW4US is offline   Reply With Quote
Old 04-07-2009, 10:31 AM   #14
1987 32' Excella
Poplar Bluff , Missouri
Look at it this way, you won't have to worry or stew about putting the first dent in your Airstream...it's already there! See all the grief it has saved you?
My guess is, if it's been on the road more than once, there's at least a rock dent, or a door ding, or...well, you get the idea. Are there any perfect 'Streams out there over 5 years old, with no dents, dings, or blemishes on the skins? Its kind of like us as we age, the wrinkles and scars give us character, show we've actually lived!
Steven
StevenG is offline   Reply With Quote
I'm afraid this is going to be expensive... Stefrobrts 1966-68 Caravel 236 03-06-2018 08:35 PM
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
What is the least expensive insurance ctdair Insurance & Claims 13 09-23-2006 12:34 PM
Can this be repaired for $5K? yukionna Our Community 41 02-11-2005 09:15 PM
Airstream or less-expensive others? kenlad Our Community 12 07-18-2004 03:54 PM
