Old 08-12-2013, 06:55 AM   #1
Dickandvicki's Avatar
1991 29' Excella
Tulsa , Oklahoma
Is this a big deal?
Hi Everyone,
I'm going to make the final payment and pick up my new (to me) '90, Excella, 29ft. . I was just wondering if this dent could be pulled out? The seller said he was told that the whole section needs to be replaced. The dent is purely cosmetic and didn't pierce the skin. Also, some of the clearcoat is pealing. It's not too big of a deal is it? Just getting a tiny bit nervous..
Vickie
ID:	192998   Click image for larger version
Dickandvicki is offline   Reply With Quote
Old 08-12-2013, 07:14 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The only dent I am seeing is the one on the street side lower corner from behind, right? Well, you would probably have some luck sticking a suction cup or hot glue dent puller to it, and giving a yank. The dent might pop out, but you will still see a little bit of a wrinkle where the dent had been. If it is anything like the dent I had in my trailer, a slight pressure will make it pop back in again, so you will need to keep that suction cup handy. The only way you are going to get this to look perfect again is with a panel replacement.
The sad reality is that clear coat peels, and the older the trailer gets, the more it is going to peel. It's not a defect specific to your trailer, just something that will inevitably happen to all clear coated trailers. As a 1990 model, this trailer is nearly 25 years old. It almost qualifies as vintage, so if peeling clear coat is the worst you have to deal with, then you aren't in bad shape.
Good luck!
Old 08-12-2013, 07:26 AM   #3
Originally Posted by Dickandvicki View Post
Hi Everyone,
Vickie
The clearcoat back then was good for 5 to 6 years, and then crystalizes and starts to fall off in places.
You can live with it, or have it recoated
Recoating would cost about $ 2500.00.
Old 08-12-2013, 07:44 AM   #4
1991 29' Excella
Tulsa , Oklahoma
Thank you so much for your reply.. I am okay living with the dent, but I could get the dent out I would like to do that.. Just getting nervous, shaky, panicky making the big leap into buying an AS.. )
