Old 11-14-2014, 04:02 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Is there a horizontal stringer in the side?
I'm considering adding a grill mounting rail on the curbside of my 2001 Safari 25. The only rail I can find for my grill is 16.5 inches long. No vertical ribs are that close. While looking at the trailer today I observed a horizontal row of rivets about a foot over the wheel wells on both sides. On the curbside it runs from the furnace to the rear storage compartment (twin bed model). Edit: I just noticed it goes forward of the door as well. Is there a stringer behind this row of rivets that would support a grill rail and grill?
Name:	Trailer side rivets.jpg
I have the Camco/Olympian 5500 that comes with a dual purpose mount. You can sit it on a table, which is what I have been doing, or hang it on a rail on the trailer.
Name:	Grill mounted.jpg
I think it might even be OK screwed into the skin, but I'd rather put it on a structural element. The arms put a torque on the mount that the mount translates into a tension force on the top rail and compression on the rubber feet at the bottom of the frame. I have placed the mount against the trailer and pressed on it as the grill would and the feet do not deform the skin at all.
Can I screw (or rivet) the mounting rail along the rivet line pictured above and catch a structure behind the skin?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-14-2014, 04:17 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Rivets usually indicate a rib. You should be able to press and feel if a rib present in that location.
MICHAEL
help with my horizontal tanks ecgds LP Gas, Piping, Tanks & Regulators 7 02-16-2007 05:11 PM
plastic end caps for horizontal blinds bpcaudill Upholstery, Blinds, Walls & Interior Finishes 6 09-26-2006 07:44 PM
Horizontal LPG Bottles on "Limited" models Dwight LP Gas, Piping, Tanks & Regulators 15 05-31-2005 07:18 PM
Horizontal LP Tanks? Ga Pockets 1984-1988 Limited 1 12-28-2004 03:39 PM
valves for horizontal lp tanks? Oak LP Gas, Piping, Tanks & Regulators 1 10-20-2002 11:26 AM
