Old 08-24-2012, 07:03 PM   #1
1977 31' Sovereign
Lakeway , Texas
Is my door doomed?
This is our first AS and I thought of just getting another door and moving on. Then after much reading I'm understanding that new doors are very expensive and each door is a little different. So my question is, is there any saving this door? What would be the best way to repair it?
ID:	166661   Click image for larger version
ID:	166667   Click image for larger version
Kevrey50 is offline   Reply With Quote
Old 08-24-2012, 08:07 PM   #2
Goal15's Avatar
Dallas , Texas
Search the site because there have been a couple threads on door repair
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 08-24-2012, 08:25 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
You will probably need new skins but I bet you can get the frame back to the right shape with some heat from a torch. Low heat. Don't melt anything.
It will just take time.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-24-2012, 08:37 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the door has an extruded aluminum frame, you can reshape it. I would not use heat. There is a possibility of annealing it. Which will make it really soft and easily bent again. While aluminum has some memory, it is nothing like steel. If you make forms to shape the frame and clamps to move the metal as opposed to hammering it. You will get better results. Take your time and think about the results you want.
Old 08-24-2012, 09:03 PM   #5
1977 31' Sovereign
Lakeway , Texas
So what I'm picturing is making a jig that matches the curve of the shell by the door (the curve needs to be slightly more than the shell). Then removing the door and clamping the top first to the jig. (the top doesn't have any damage) Then working the rest of the door into the same shape. By the way the frame is completely broken in two around the deadbolt receiving cup. I'm guessing tig welding will be in order for there. Should I beef up the frame by adding a new piece of aluminum riveted to the inside of the current frame. I'm thinking this would help protect the weakened areas from bending again.
If my logic is flawed please let me know!!
www.anOldairstream.blogspot.com
Old 08-24-2012, 10:14 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like you are on the right track. If it is possible to have the broken section welded. I would have it welded while it is held in the jig.
