Old 06-25-2007, 07:34 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Is Aluminum Aluminum
I need to replace two sections of belly wrap. The manual I have shows the material to be 3004 aluminum sheet .024 thick. All I can find so far is 3003 sheet .025 thick.
So is the difference any big deal or will one do just as well as the other.
Old 06-25-2007, 07:40 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
To me, a thousandth of an inch wouldn't make much difference, especially if it is going on the belly pan.
Old 06-25-2007, 07:45 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Thanks - it's actually going to be visible - here is a photo of one of the problem areas. It was creased by the PO and I presume touching the outrigger - difference in the metals caused the corrosion...??? This is just rear of the door.
Old 06-25-2007, 09:27 PM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
No aluminum isn't aluminum, it's aluminium
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-25-2007, 09:37 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Is there an answer in the extra " i "....?
Old 06-26-2007, 08:03 AM   #6
Well Preserved
1993 21' Sovereign
No, it's just an effect of breathing the fresh smog, er, air in L.A.
I don't think the extra .001" is going to make much difference in the bananna wrap, either.
Old 06-26-2007, 09:47 AM   #7
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
the thickness is not going to make much difference. the alloy might. although 3003 and 3004 do not seem to have much difference in alloying metals.
Michelle TAC MT-0
Sarah, Snowball
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 09:32 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
