Old 05-01-2013, 10:17 AM   #1
Airstreamer NW
2010 25' FB Flying Cloud
Fall City , Washington
Interor rivet replacement
My 2010 25 FC has lost four rivets in the interior since new.
two are about six feet apart above the sink side. the other two are next to each other when the top panel overlaps the lower panel at the narrow connection between the rear quarter window and adjacent left side large window. These two have for some reason gotten the two sheets of aluminum a little out of alignment. do I simply drill out the holes to align or do I attempt to work the panels into hole alignment.
I used to do aluminum work years ago and am experienced in rivet gun use.
Any recommendations would be appreciated.
Lou
Red Hound is offline   Reply With Quote
Old 05-01-2013, 10:37 AM   #2
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We had four fall out also. We just replaced them in the original holes, but it didn't take much manipulation to have the holes line up again.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
