Old 09-14-2011, 11:53 AM   #1
1981 31' Excella II
New Market , Alabama
Interior Rivets - What size?
I am going to have to put my interior skins back on when I get my floor finished and I was wondering what the sizes are. They looked to be 1/8" diameter rivets. I ordered some 1/8" and 3/6" rivets. Also do you put the same size pop rivet back when you replace them or do you go up to the next size?
What is the proper way to remove rivets? I have always used a bigger drill bit than the hole and drill till the head pops off. Would it be better to use a 1/8" drill bit and drill all the way through?
Perry
Old 09-14-2011, 12:12 PM   #2
Perry
Perry.
There are only 3 drill bit sizes for all your Airstream work.
#30 fpr pop rivets
#21 for Olympic rivets
#10 for the 3/16 inch underbelly rivets.
All the interior rivets use a #30 drill bit.
Old 09-14-2011, 12:16 PM   #3
Perry
Perry.
Sorry, but I made a typo.
The 3 sizes of drill bits are # 30, # 21 and # 11.
Old 09-14-2011, 01:18 PM   #4
Central , Mississippi
Ive had good luck drilling out the interior rivets with a 1/8" bit and using 1/8" aluminum cored pop rivets to reassemble. It's been my experience that many times the rivet head will still shear off, leaving the body in the rib. I use a angle grinder with a flap wheel to flush off the rivet to the rib, then a center punch to push the rivet out of the hole.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-14-2011, 01:29 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I use a stop block on the drill. Sometimes it can self feed and I would hate to go all the way through. I just take a dowel or small wood square, drill it length wise, the cut it off so that it will only let less than 1/2 inch of drill out. slip it over the drill so it jams against the chuck.
Bill M. is online now   Reply With Quote
Old 09-14-2011, 06:30 PM   #6
1981 31' Excella II
I have found a better way than the drill. I found out that tonight that a real sharp wood chisel will cut the head off a rivet with little or no damage to the panel. This is the only way I have found to get out rivets hidden behind panels.
Perry
Old 09-14-2011, 06:56 PM   #7
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
You'll be fine to install 1/8" pop rivets back assuming the 1/8" that you removed came out OK and you didn't need to enlarge the hole due to damage or corrosion. The next std size of pop rivets is 5/32" which requires a #20 drill bit. Keeping the rivet size minimal will help to maintain the required edge distance
truckasaurus is offline   Reply With Quote
Old 09-14-2011, 07:33 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
I fully concur with this. I had an exterior compartment door hinge riveted with about 2 dozen 1/8" rivets come loose after a recent long trip.
Unless the drilling out goes real true (most of them do), I hollow grind the rivet head with a Dremel before I drill out with an 1/8" bit. The underlying hole is sometimes oblong but it takes a lot of enlargement before I'll drill a very few for 3/16". 'Medium' is the most common length unless I'm dealing only with a skin-skin hole (and then 'short' of course).
HiHoAgRV sez it right -- use aluminum core pop rivets. Though surprisingly there were some steel cored rivets used by the factory on my '74 Argosy's rubrail. Musta had to run out to their friendly ACE hardware that day...
5 meter Langford Nahanni
Old 09-15-2011, 07:11 AM   #9
If you check the size of a # 21 drill, you will find that it's a much tighter fit, for the Olympic rivets, and far less likly to loosen and leak.
Certainly much better than a #20 drill.
Old 09-24-2011, 03:05 AM   #10
1966 17' Caravel
Metairie , Louisiana
Drill bit conversion table
Is there a reason for using #30 instead of 1/8" and #21 rather than 5/32"?
Found this conversion chart.
Name:	drill bit conversion.jpg
brusby is offline   Reply With Quote
Old 09-24-2011, 04:07 AM   #11
Those sizes are recommended by the RV industry, especially Airstream.
Some disagree about the #21 and use a #20.
We feel the #20 is an excessive size hole.
Certainly, the tighter the better.
Old 09-24-2011, 06:30 AM   #12
1981 31' Excella II
I think it is because the hole has to be a little bigger than the rivet to you can insert the rivet. Also the metal expands a little making the hole a little bigger when the rivet is installed.
I may put sheet metal screws back in so I can get the panels off without a major hassle.
Perry
Old 11-06-2011, 08:00 AM   #13
1972 25' Tradewind
Madison , Wisconsin
drill bit chart
FYI
try this chart
Drill Bit Size Chart
Smokin Camel is offline   Reply With Quote
Old 11-06-2011, 08:19 AM   #14
Wooden Rivet's Avatar
1956 26' Cruiser Overlander
McLeod , Texas
Can anyone tell me the correct size drill for buck rivets on an Airstream?
Tom
Wooden Rivet is offline   Reply With Quote
Snap Size '65 Tradewind? P&A Upholstery, Blinds, Walls & Interior Finishes 2 07-16-2011 03:27 PM
POLL: AC BTUs, Trailer Size, and Climate Shiloh Furnaces, Heaters, Fireplaces & Air Conditioning 19 05-14-2011 10:51 AM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
28' Ambassador v. smaller size Airstream Nigel Member Introductions 13 01-25-2011 04:34 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
